Ls Build help (first build)
Old Sep 19, 2010 | 06:23 PM
boostedls92's Avatar
Default Ls Build help (first build)
Hey,
I have a stock ls(a1) Running 11psi good tune
Now I've never built a engine before, i got idea and looked up some parts,but i don't know what to do. I've boosted many cars and also blown up many cars
I've also heard, don't push more then 230whp on a ls stock.
What i need help on is basically i push in the right direction,but i want to keep the stock compression 9.2:1
I'm looking for a basic build for a decent amount of boost and whp
rods,head studs,bearings,and pistons
cams and other power adders will come later
What brands to get without braking the bank?
Old Sep 19, 2010 | 10:13 PM
adam00's Avatar
Default Re: Ls Build help (first build)
Google nippon racing pistons and look at other peoples builds to get some ideas
Old Sep 19, 2010 | 10:29 PM
sik96teg's Avatar
well the right direction differs for everybody due to 2 main factors money and power goals. So would this be a budget build and what power are you looking for. Also from what i have heard any healthy b series motor is reliable to 300whp but if this is ur DD then a few upgrades would def help the reliability and help you obtain your power goals with less boost.
Old Sep 20, 2010 | 04:43 AM
money is $1500
and power goal is 250whp+
Old Sep 20, 2010 | 05:00 AM
Bonestock98GS's Avatar
Ok I got my set of Supertechs brand new in the box for super cheap. They are 9:1 81.5mm bore. If you go with a combo you may spend about $750 on a combo which aint bad. You cant really lose with any forged piston you get. Nippon is still like a cast LS piston. Not knocking them or anything. Rods for that power goal id get Eagle rods. ACL race or standard bearing which ever one that is needed when you plastigauge to find out clearances. And ARP everythign for the fastners.
Old Sep 20, 2010 | 05:12 AM
thank you, I'll look into them
Old Sep 20, 2010 | 05:15 AM
About to order some eagle H-beam rods for $296.14 Good price?
Old Sep 20, 2010 | 08:40 AM
You can save six dollars here http://www.slowboyracing.com/eagle/e...d/i-54664.aspx
And they ship them fast thats who I got my pistons from. Great guys to deal with
Old Sep 20, 2010 | 11:12 AM
thank you
Old Sep 20, 2010 | 06:40 PM
05si90hatch's Avatar
Crower stage 1 N/A cams
forged rods of your choice
srp pistons are cheap goodness, nippon pistons are cheaper goodness
Bottom end will be solid and with the cams you will probably hit the power you are wanting without increasing your boost.
Old Sep 20, 2010 | 06:46 PM
Thanks. i'm thinking i'll spend about 1000-1200 on this build for right now
Old Sep 20, 2010 | 07:05 PM
93ls10.0's Avatar
wiseco pistons, eagle rods, acl rod and main bearings. makes a solid bottom for what you wanna do. Thats what my ls has but i have delta cams,sk2 springs& retainers, etc
22accordts
Jun 6, 2013 02:24 AM
Skatnshawn
Engine Management and Tuning
Nov 1, 2012 04:42 PM
eg9ferio
Jun 25, 2008 07:34 PM
Civicman86
Jul 29, 2005 05:05 PM
Touge Tuning
Jan 13, 2005 01:21 PM
