Lower final drives?
Old Feb 13, 2005 | 07:53 PM
  #26
MidShipCivic's Avatar
Default Re: (UberTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UberTeg &raquo;</TD></TR><TR><TD CLASS="quote">yes, 6 puck</TD></TR></TABLE>
Well, thats one of the problems contributing to you spinning through you primary gears.
Old Feb 13, 2005 | 08:16 PM
  #27
UberTeg's Avatar
Default Re: (MidShipCivic)
how? I can spin them rolling into it.
Old Feb 13, 2005 | 08:28 PM
  #28
6 puck are harsh engagment clutches that shock the driveline, causing you to spin.
I would use a full face clutch of course with a ideal pressure plate.
Don't understand enough look at this : http://www.daliracing.com/v666...D=458
Old Feb 14, 2005 | 03:10 AM
  #29
UberTeg's Avatar
wow, good read thx
This act clutch is pissing me off anyways, might be time to replace it.
Old Feb 14, 2005 | 06:23 AM
  #30
rioninja's Avatar
Cant help with the final drive, besides suggesting you give GearSpeed a call:
http://www.gear-speed.com
Maybe in the meantime you should work on the suspension a little. Help with
the weight transfer.
Old Feb 14, 2005 | 09:06 AM
  #31
DIRep972's Avatar
Smarter than you
Default Re: Lower final drives? (UberTeg)
If you could post your dyno I could figure out ur optimal shift points for u. (unless you already know how to do that)
So you already have a hydro LS tranny? w/ the 4.26 final drive? or do you have the cable w/ the 4.40 fd? If you're maxing out the 4.26 you must be going about 115mph in the 1/4.
And you are completely against going to a larger tire? If you could go 1" taller on the tire and 4-500rpm higher in the rev's you'd get an extra 10mph out of the car in the 1/4.
Old Feb 14, 2005 | 12:10 PM
  #32
Def's Avatar
Def
I can spin 1st, 2nd, and part of 3rd. I think those gears account for more than 5% of the 1/4.
Why not attack the problem directly and get more traction(slicks/drag radials, something) instead of lowering your drivewheel torque?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
What is so different about me getting larger slicks and lowering my diff? The end result in the same. Lowering the gear ratio should help my 60ft out too.</TD></TR></TABLE>
Putting in a lower FD is much more of a pain in the *** than bolting up some larger tires that also give you MORE TRACTION.
jerzey908
Oct 18, 2012 09:29 AM
hmonkey86
Mar 4, 2012 05:51 AM
killerpenguin21
Jun 1, 2008 07:46 PM
Duster
Feb 18, 2004 01:20 PM
gary201147
Dec 15, 2002 08:40 AM
