lower compression via gasket or keep high compression?
Old Jun 2, 2003 | 10:39 AM
madman604's Avatar
Default lower compression via gasket or keep high compression?
stats below:
should i drop the compression of my motor and run more boost (safer?) or keep the comp as is and run more boost?(more tuning?)
I was thinking of going with an Inline pro 2mm gasket.
which would also give me more power?
this is my daily driver so I cant afford to go boom.
thanks for any input on this.
Old Jun 2, 2003 | 11:09 AM
FFormula1's Avatar
Default Re: lower compression via gasket or keep high compression? (Turbo E)
A thicker head gasket will reduce the quench effect which acts as mechanical octane to prevent detonation, if you want to lower the C/R get new pistons.
ojasia
Jul 13, 2014 08:24 PM
golf-mk3
Feb 22, 2010 07:00 AM
Hybrid 350GT
Apr 23, 2003 08:33 AM
