low compression how much nitrous???
Old Feb 19, 2008 | 04:54 PM
boostedcoupe1's Avatar
Default low compression how much nitrous???
ok look guys...i know that there have already been postings on this, but noone has answered how big of a shot you can put on say an 8.5:1 wiseco pistons, eagle rods in a b20b with a b16 head. i had a turbo but sold it...my motor is fresh and i dont have the money to rebuild it right now...when i do get around to rebuilding it, i will probably be somewhere close to 12:1 cr and spray on that...right now i have my timing advanced all the way at the distributor and im shooting a 100hp wet shot...it just feels weak, had the same shot on my buddys car and it is pretty nasty...i know this is because of the compression ratio, so my question is, how big of a shot can i run on that built setup???
Old Feb 19, 2008 | 04:58 PM
Attaus's Avatar
Bring your timing back to neutral and increase the shot to 125. If you don't hear any pinging go up to 150. I don't see a problem with 175 if you have a fully built motor and 8.5:1 compression.
What kind of hardware did you use? Are the rods, wrist pins, head studs, etc all new?
Old Feb 19, 2008 | 05:00 PM
fmfkid250's Avatar
With the right gas and tune. The sky is the limit.. There is a whole big Nawz thread. not to many people Get into it though.
Good luck Add more. Stock sleeves? 400hp? With sleeves? 600hp
-Joe
Old Feb 19, 2008 | 05:46 PM
Default Re: low compression how much nitrous??? (boostedcoupe1)
ok guys...thanks for the info...i have stock sleeves, but everything else is upgraded...arp rod, main, and head studs, acl race bearings...i was puttin down over 400whp on the turbo setup...so i will up the shot and see what happens...thanks guys
Old Feb 19, 2008 | 05:49 PM
also...can i leave the timing advanced if there is no detonation??? the car is slow as dick without it advanced
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcoupe1 &raquo;</TD></TR><TR><TD CLASS="quote">...so i will up the shot and see what happens...thanks guys</TD></TR></TABLE>
Bad attitude.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcoupe1 &raquo;</TD></TR><TR><TD CLASS="quote">...so i will up the shot, get it tuned, and see what happens...thanks guys</TD></TR></TABLE>
There ya go...
15to1
Jul 17, 2006 10:36 PM
HYBRID FREAK
Jul 13, 2006 07:58 PM
slo_crx
Nov 5, 2004 04:02 PM
93gen2
Jun 27, 2004 11:14 AM
xxplosif1
Sep 18, 2002 06:24 AM
