comment on my compression please
Old Aug 2, 2002 | 03:05 AM
Cyber ITR's Avatar
Default comment on my compression please
200 across , cranked it like 5-6 times
JDM B18C
compression seems to be too low for a B18C right ?
hiks
Old Aug 2, 2002 | 05:10 AM
RGAZ's Avatar
New User
Default Re: comment on my compression please (VTEC_SiR)
Nope. Right on the money. You will probably not see anything higher than 215 ever, so 200 across is good. Start seeing 150 and you got problems.
Randy
Old Aug 2, 2002 | 06:11 AM
GruvyTune's Avatar
New User
Default Re: comment on my compression please (RGAZ)
if you have lower compression pistons, does it affect compression testing at all?
Old Aug 2, 2002 | 06:36 AM
M.A.R.C.'s Avatar
Default Re: comment on my compression please (GruvyTune)
hey i have a question bout compression tests... i did mine... and i cranked it as many times as the haynes manual said... and i kept coming up with like 230ish across the board i think it was... this is in a stock d16y8 w/ 40000 miles and it's been thru 3 months of nitrous use. Am I doing something wrong?
Old Aug 2, 2002 | 06:41 AM
IHaveTurbos's Avatar
Default Re: comment on my compression please (CivicRyda2k)
Did you disable the fuel system before you did the compression test? This could cause you to get false reading's, cause the injectors are still dumping fuel into the cylinder.
Old Aug 2, 2002 | 07:16 AM
M.A.R.C.'s Avatar
Default Re: comment on my compression please (Hyundai4G63T)
yah did that
Old Aug 2, 2002 | 07:30 AM
I don't know what would cause you to get reading's like that then!!!!!
Old Aug 2, 2002 | 07:48 AM
GSRwBOOST's Avatar
low compression will give you lower numbes..
i had 10-1 stock and got 200-220
and
now i have 8.5-1 and get 180psi in all cylinders
low numbers or numbers that vary indicate worn rings....
Old Aug 2, 2002 | 02:48 PM
Cyber ITR's Avatar
so if the injectors still pumping fuel into the cylinders , will it get higher reading or lower reading ??
thanks
Old Aug 2, 2002 | 03:02 PM
BHSCGSR's Avatar
190 across the board for me.
Somewhat low for a GSR but......Stock bottom end with 65k, 3 15lb bottles of NOS, and the last 20k with a S/C at 8lbs.....
Old Aug 2, 2002 | 03:20 PM
dirtySOHC's's Avatar
holy ****.....230 on a y8. i dont know wat to tell you but i get 180 on my motor. you must have some serious carbon build up but still those mumbers are really high.
Old Aug 2, 2002 | 05:24 PM
niedejb's Avatar
Default Re: comment on my compression please (dirtySOHC's)
Say you find one lower than the others. I know piston rings is first culprit, but could there be a valve issue instead?
Old Aug 2, 2002 | 05:37 PM
Default Re: comment on my compression please (niedejb)
leak down test
Old Aug 2, 2002 | 05:39 PM
Sonny's Avatar
You guys are neglecting to mention the variance between gauges.
My B16A2 showed anywhere from 200 to 225 psi on every cylinder depending on which compression gauge I used (Sears, Matco, Snap On)
Sonny
Old Aug 2, 2002 | 05:40 PM
niedejb's Avatar
Still doesnt tell you where the leak is coming from.
Old Aug 2, 2002 | 09:28 PM
Cyber ITR's Avatar
Default Re: comment on my compression please (GSRwBOOST)
and
GSRwBOOST : is that mean if i have 200 across but very consistent my rings are OK ??
thanks
ef_si
Jul 25, 2013 02:09 PM
fusion645
Jan 10, 2011 05:40 AM
wink11290
Jul 6, 2007 07:00 AM
builtprelude
Jan 22, 2004 10:49 PM
stupidfast
Oct 20, 2002 03:50 PM
