low comp. piston nitrous
Old Oct 23, 2010 | 10:08 AM
LSVTECEF91's Avatar
Default low comp. piston nitrous
have a sleeve ls block 84mm with cp 9:5 pistons and rods...wondering how much nitous boost it can take direct port going with zex but if i need to go with nx heard that it was better i will buy it...port intake side on the head and blox compitition type c (HSL) flat vavles, ti retainers, dual vavles springs bottom end is fully built dont know wat type of fuel and injectors needed...need help on that trying to shoot for low 11s any info will help and not be hated...thank u
Old Oct 23, 2010 | 11:02 AM
bauergold's Avatar
Default Re: low comp. piston nitrous
It really depends on your nitrous experience. That setup could take a lot of nitrous with the right person tuning. I don't want to say how much it will handle, because you will always get bitches saying, "No it can't!"
Nitrous also likes higher compression, as long as you have the octane to support it.
Old Oct 23, 2010 | 11:07 AM
cibao2ner's Avatar
thats a 300+ shot st up...if you tune it right...
Old Oct 23, 2010 | 11:33 AM
tagperformance's Avatar
+1 and you don't have to use low compression either. There are many setups where people have high compression pistons and run big shots of nitrous. so 9.5:1 comp is very safe for a big shot and for one nitrous doesn't pressurize the cylinders like a turbocharger. I'd get an nx dual stage progressive kit. run a 125shot on the first stage and a 250 shot on the second stage and you have room to grow from there. as for s fuel system i'd get some ID1000cc injectors and run 2 fuel pumps. I'm pretty sure with that setup your would reach your goal pretty easy. the most important thing will be your tuning and ems your using. Take the car to someone who has alot of experience with big shot nitrous cars. hope this helps
Old Oct 23, 2010 | 02:37 PM
LSVTECEF91's Avatar
ID1000$$$$ wow...but i will buy it but do you think i need the bosch pump too if i have that do i still need another fuel pump?...650$ for the set
Old Oct 23, 2010 | 02:38 PM
LSVTECEF91's Avatar
LMAOL TRUE ON THAT
Old Oct 24, 2010 | 12:49 PM
the fuel system is the most important thing on any setup. Just think your goals will be dictated by how much fuel your car can support for any given platform. If it's really a strain on your wallet then you can just run a walbro hp255 high pressure pump and add a kenne bell boost a pump voltage stabilizer box for your fuel pump. this way when the car is seeing high loads at high rpms the voltage doesn't drop at the fuel pump.
Old Oct 26, 2010 | 05:13 PM
LSVTECEF91's Avatar
i will sure contact you when i have everything ready to go..remeber this post....oh n i think i'll just stick with the bosch 300...pump and injector combo...cause if i buy the injectors and pump's (walbro) kennel box it'll be a lil more...
Prudz_lude
Sep 15, 2006 11:43 AM
g-ride-si
Feb 2, 2006 12:16 PM
sracing
Jul 19, 2003 09:24 PM
zilverz
Oct 28, 2002 12:06 PM
