Low boost system, couple questions.
Old Nov 1, 2005 | 01:15 PM
psyphre's Avatar
Default Low boost system, couple questions.
Looking to run a low boost (5psi) just for some extra oomph. As far as fuel, will a fuel pressure riser be adequate? What do i need to get around the map sensor? anything else i should know?
Old Nov 1, 2005 | 01:26 PM
bubs's Avatar
Almost everyone here will tell you to stay away from FMU's, but as long as you don't go above 5psi or so, it will probably work alright. Here are the things you'll need:
FMU: maybe a 10:1 or 12:1
Inline fuel pump (don't try to use the in-tank pump by itself!)
Missing Link (for the map sensor)
Good luck
Mr.DC2TurBo
Jan 3, 2004 09:56 AM
Elite Hatch
Sep 27, 2002 02:39 PM
ATgrills.com
Sep 20, 2002 08:59 AM
b18cTurbo
Nov 18, 2001 09:19 PM
Drboosted
Jul 18, 2001 09:36 AM
