Loud Valvetrain?
Old Nov 14, 2003 | 08:23 AM
TurboB18B's Avatar
Default Loud Valvetrain?
I am hearing a lot of noise coming, sounds like ticking coming from my engine at idle. You cant hear it with the fuel pump from inside but if you pop the hood and listen in the engine bay you can hear it loud and clear. Do i just need to adjust my valves or is this a sign of bigger problems? I think it is just some valve lash but not sure. Also does anyone else have a loud inline pump? Mine makes a lot of noise as of late and should i upgrade to an intank? I have the usual 12:1 fmu and stock everything else except fot the pump? Thanks for any help.
Old Nov 14, 2003 | 08:25 AM
redboost10's Avatar
Default Re: Loud Valvetrain? (TurboB18B)
could be valves, could be forged pistons and rods. is it like chattering?
Old Nov 14, 2003 | 08:59 AM
HybridKOOP's Avatar
Default Re: Loud Valvetrain? (tgh99si)
Sometimes a "tick" can come from injectors as they fire. Just a thought.
Old Nov 14, 2003 | 09:08 AM
Johnyquest's Avatar
Default Re: Loud Valvetrain? (HybridKOOP)
Yeah, my DSM injectors are very loud, but I doubt that's your problem b/c my stocks never were, and you said your on an FMU, so I'm assuming stock injectors.
I'd adjust your valves first, and if that doesn't do the trick, go to a slightly thicker oil. That'll help.
Spody02
11
Jan 8, 2009 07:02 PM
Mr.DC2TurBo
Sep 25, 2003 09:51 PM
live4speed
11
Aug 18, 2003 01:12 PM
SixPAK
10
Feb 13, 2003 12:29 AM
carcala
May 29, 2002 10:54 PM
