loud ticking...
Old May 9, 2005 | 02:57 PM
  #26
dustin's Avatar
Default Re: (mike93eh)
Get one of these:
You can get a cheap one at autozone.
Old May 9, 2005 | 03:12 PM
  #27
mike93eh
Guest
Posts: n/a
well if its an exhaust leak. i know where its at and there isnt much i can do about it besides taking the exhaust chamber off and have it milled or spray a ton of copper spray on it.. which im not going to do all that because of a ticking sound.
Old May 9, 2005 | 03:15 PM
  #28
dustin's Avatar
But it might not be an exhaust leak.
Old May 9, 2005 | 03:31 PM
  #29
dornon13's Avatar
Default Re: (dustin)
i had a pretty big exhaust leak and i could hear it as a ticking sound i had no clue it was exhaust related because it didnt sound like that...i was trying to find out where it was coming from in the head because it sounded like valves tappin or something but back on topic i guess by now you have checked for this?
Old May 9, 2005 | 07:58 PM
  #30
redturbosi's Avatar
i recently bought a 95 gsr with a built bottom end and jg pro series head. i was told about the ticking coming from the head and that he just thought it needed a valve adjustment . got it done and still ticked. took to my buddies shop and he told me i need a lost motion assembly ITR. HE TOLD ME THEY WERE EXPENSIVE AND from the dealership would cost about 380. i found a guy on ebay who sells them for 220 oem itr. thats about 160 less than retail.
Old May 9, 2005 | 08:09 PM
  #31
crucian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Get one of these:
You can get a cheap one at autozone.</TD></TR></TABLE>
Haha.... I had to pull mines out yesterday to see what was making the tapping noise in my engine. Found out it was the valves for me. Well, hopefully!
Old May 9, 2005 | 08:33 PM
  #32
EJ1 wilcox's Avatar
Default Re: (crucian)
My engine ticks too....
I have a long like 3 foot long extension, I can put my ear to one end and touch the other end to different parts on my engine to hear the ticks... I'm about 99.99% sure it's just my damn DSM 450s... those things tick like a ****...
I watched SOHC_MShue's video, my car sounds similar.
Old May 9, 2005 | 09:52 PM
  #33
SOHC_MShue's Avatar
Default Re: (EJ1 wilcox)
yea man i swear now that i put a new block in my car that it ticks louder than before, but when i listen to that old video it sounds exactly the same. I think i'm just paranoid
Old May 9, 2005 | 10:10 PM
  #34
V-SPEC 1's Avatar
Default Re: (SOHC_MShue)
Do the plug wire trick and see if you don't have a knock on your bottom end. Start the car and pull one plug at a time and see if it goes away when you pull it out. if you pull one and it goes away, try put it back on and see if it comes back. If it does, you have spun the bearing.
Old May 9, 2005 | 10:15 PM
  #35
crucian's Avatar
Default Re: (V-SPEC 1)
Yeah I am going to try that. I wanted to, but I am tired of getting shocked from my MSD ignition!
Old May 9, 2005 | 11:56 PM
  #36
redturbosi's Avatar
heres the guys description on ebay who sells them. ......
Up for auction is a set of BRAND NEW genuine Honda Integra Type R Lost Motion Assemblies. These are an excellent upgrade for all B16 and GSR owners. Type R Lost Motion Assemblies are commonly overlooked when people build engines. If you are using Type R cams or cams with even larger profiles these are a must! City Speed has plenty of these Lost Motion Assemblies stocked in our warehouse ready for immedtiate delivery! Keep in mind that our Buy It Now Price is over 45% off of retail!
Retail Price Including Tax Is $387.90
this could be your problem. not alot of people know about this. if you have had cams put in your car this is probably your problem.
Old May 20, 2005 | 01:56 AM
  #37
crucian's Avatar
Well after 400miles of diving and my car still ticking loud as hell, I decided to take my car to a Honda dealer hear in Germany. After they did a valve adjusment and test drive, they said that the ticking noise was gone. Unfortunately when I started the car, it ran like **** and the noise was still there. Anyways I paid them a lot of money, cause their money owns the US Dollar, with nothing fixed. Me and the mechanic both agreed that it could be the injectors or valve. Long story short, I went and bought some Dura Lube fuel system cleaner and lubricant, put it in yesterday, and to my suprise the noise got a lot more quiet!!! Well hopefully it stays quiet. I can't hear the noise from upstairs in my apartment anymore. And Im not ashamed to drive it anymore either.
Old May 20, 2005 | 02:15 AM
  #38
EnzoSpeed's Avatar
Just to add some input...
I put some DSM 450s in my civic and they didn't sound any different than stock... Maybe it's because they were balanced/blue-printed/whatever by landspeedracing before I installed them.
Old May 20, 2005 | 03:12 AM
  #39
BoostedEG6's Avatar
Default Re: (EnzoSpeed)
check your Idle Air Control valve..... I know they can tick when they are bad. Mine is ticking loud as hell......
Old May 20, 2005 | 08:43 AM
  #40
J337_UNIT's Avatar
Default Re: (BoostedEG6)
could be that you need to do a valve lash adjustment
Old May 20, 2005 | 10:42 PM
  #41
crucian's Avatar
I have srock in jectors. I dont think the injectors is what's ticking so loud. I think it's the valves. I have KMS engineering valve springs in. Way stiffer than stock. I'll just have to deal with it I guess. I did a valve adjusment 3 times and honda did it 2 times.
Old May 20, 2005 | 11:04 PM
  #42
97BLACKCIVIC's Avatar
Default re
It could be
Injectors
Valves need to be ajusted
Valves bent but u say the car runs perfect
Timing belt- possible- it does it on my friends
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">check your Idle Air Control valve..... I know they can tick when they are bad. Mine is ticking loud as hell......</TD></TR></TABLE>
I think he means it being a consistant tap, not a click, because he says it does threw all rpms, and your IVAC doesnt open and close when you give it full throttle. ya know.
bearings- possible- due what he says-&gt;<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-SPEC 1 &raquo;</TD></TR><TR><TD CLASS="quote">Do the plug wire trick and see if you don't have a knock on your bottom end. Start the car and pull one plug at a time and see if it goes away when you pull it out. if you pull one and it goes away, try put it back on and see if it comes back. If it does, you have spun the bearing.</TD></TR></TABLE>
And exhaust leak- look for black spots on the head where it could be leaking, even on cast parts it shows. when your motor is cooled down, have some one start it and you put your hand around the exhaust and turbo and see if you feel a leak or just go and do what he says, hell of a lot easier--&gt;<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Get one of these:
good luck
Old May 21, 2005 | 12:53 PM
  #43
i3oricua's Avatar
Default Re: re (97BLACKCIVIC)
I agree with most everything 97blackcivic said. Do you smell fuel in the car or in the engine bay? I once had a cracked injector and ticked pretty loud and you could smell the fuel pretty good. Also had an exhaust leak that ticked REALLY loud. I just took the gasket off and mated it straight metal to metal. Noise was practically gone. Just my .02
Old May 22, 2005 | 07:51 PM
  #44
mike93eh
Guest
Posts: n/a
its not the injectors or valves or iacv or timing belt. i checked for exhaust leaks around the manifold and greddy elbow and didnt feel anything. i even bought i mechanics stethiscope and could not pinpoint the tapping noise at all. havent tried the spark plug test, will do that next. still leaning towards a exhaust leak from the greddy elbow...
Datpiff17
May 12, 2017 09:38 PM
AudioFunk
Jan 19, 2014 07:35 AM
japscrap
Jan 31, 2009 12:55 PM
stocky
Mar 15, 2007 06:23 AM
DriveSlowHomie
Aug 18, 2005 02:18 PM
