Radiator Coolant problem NEED HELP!
My car was overheating at first so i change my thermostat and was still overheating come to find out i found a small hole on the small hose that goes underneath the distrubtor i change that and started my car for a while with new coolant it didnt overheat then i check later my coolant container was almost empty i filled it up again check a couple hours later it was almost empty again also i dont know if this is normal that the coolant is bubbling up in the container anyone knows the problem really need you guys help mahalo`s..
Re: Radiator Coolant problem NEED HELP!
did you bleed all the air out of the coolant system when you changed the t-stat and hose? also, do you mean that there are air bubble coming out in the container?
bubbling coming out the container..so your saying the reservoir next to the radiator? or you open the radiator cap and it's bubbling.
i didnt bleed the air out the coolant system when i change both i only drain out the old coolant..
it was bubbling inside the container
might be my head gasket also
yeah, definatly headgasket... and depending how how much it over heated and how many times, there could be other damage too. i.e. warped head or block
Try refilling the radiator and bleeding the system first and see what happens.
If you are still getting problems get a block tester and use it,if your headgasket is gone and leaking into the coolant it will show up with the block tester.
ShadowDaisy82
11
08-07-2015 10:34 PM
