Loosing Water!!!!
Old Mar 13, 2008 | 05:10 AM
NightStalker's Avatar
Default Loosing Water!!!!
ok guys heres the thing, i fill up the radiator car runs good awsome power dyno @ 298 whp. i drive the car to work everyday about 120miles a day RT and is all HWY, so im looking about 3k miles a month last night i noticed my car was starting to over heat and i immediately pulled over and check the radiator it was empty, last time i filled it up was 2 months ago there is NO milkie stuff in the oil. Does NOT smoke, and the compression is GOOD, i did a search but couldnt find anything. what can it be?
Old Mar 13, 2008 | 05:33 AM
Default Re: Loosing Water!!!! (NightStalker)
DANG noone?
Old Mar 13, 2008 | 06:37 AM
95jeremie's Avatar
DANG no info...
what car?
what motor?
hom many psi?
built block?
head studs?
could be a coolant leak under boost... head lifting?
you said that you did a compression test
what was the results?
do a leak down test.
Old Mar 13, 2008 | 06:40 AM
kuja396's Avatar
Default Re: Loosing Water!!!! (95jeremie)
Its probably a blown headgasket, especially if it starts overheating every now and then. Thats what happened to me anyways.
Fill your radiator up and do a leakdown with the cap off. Let the leakdown force air into your cylindeer for about 30 seconds and notice if any air bubbles come out of the radiator.
Old Mar 13, 2008 | 11:27 AM
JDMs1eeper's Avatar
Default Re: Loosing Water!!!! (kuja396)
I used to get those issues every now and then. When i pulled the head it was always small tiny hair line cracks in the upper area of the sleeve.
Old Mar 14, 2008 | 03:42 AM
EK4Vti's Avatar
Do you have a cometic head gasket by any chance?
90lshb
Sep 9, 2013 12:08 PM
crcale
Apr 10, 2010 10:15 AM
BodyKits NW
Oct 8, 2003 08:13 AM
jweller
Sep 25, 2003 04:27 AM
dualknuttz1
Aug 18, 2003 10:57 PM
