loosing boost
Old Dec 20, 2006 | 07:28 AM
flangemastermike's Avatar
Default loosing boost
hi, got a problem and its driving me mad, basic b16a2 setup
stock b16a2
P fabrications log manifold
rc550 injectors
T3/t4 .57 (made in a cave but lasted 6months so far)
replica greddy type s blowoff valve
xs power 38mm wastegate
cheap ebay intercooler.
ball and spring type boost controller.
mostly cheap parts but been working for a while. only been running 3psi (wastegate spring).didnt raise the boost until i got dataloggin workin and could tune it, got wideband and everything but was havin problems. any way the real problem is when i raise the boost to 8-9psi at about 6500rpm it starts falling to about 4psi. holds 8psi in 2-3-4-5 but slowly drops everytime, thought it was a boost leak but pressure tested all pipes to 25psi (foot pump). any one got any ideas wats next to check ,
only happens at high revs and its pissin me off, im better short shifting than revin high lol. any help would be great , thanks
mike.
Old Dec 20, 2006 | 07:33 AM
DaveF's Avatar
Default Re: loosing boost (flangemastermike)
probalby that dinky *** turbo you have....
what exhuast /cat /muffler ?
Old Dec 20, 2006 | 07:41 AM
Cyberdx16's Avatar
assuming u dont hear ur wastegate open at all during these spikes from 8-3lbs?
lets see the bin aswell
Old Dec 20, 2006 | 07:51 AM
exhuast is a 3" from the turbo (home made) muffler is a straight through cheap can sounds good though. can't really hear the wastegate(screamer pipe) over the exhuast. will hunt out the bin and post it .
Old Dec 20, 2006 | 07:55 AM
DaveF's Avatar
Default Re: (flangemastermike)
bov working? maybe its not "tight enough"
Old Dec 20, 2006 | 08:32 AM
tightened it right up before to make sure. think its the wastegate but dnt know wat would cause it todo that. its stiff fuel type hose from the inlet manifold to the wastegate. maybe the cheap MBC ?.
Old Dec 20, 2006 | 02:30 PM
Cyberdx16's Avatar
yeah i would definitely agree that its ur MBC just get a new spring
Hondacivic1995
Apr 17, 2011 04:40 PM
jonnybravo
Aug 1, 2004 06:01 PM
lvf03
Mar 13, 2004 01:57 PM
fiftee_su
Jul 11, 2003 08:15 AM
