Loosing boost?
Old Apr 10, 2005 | 04:40 PM
0ptimus prime's Avatar
Default Loosing boost?
Alright i've searched this topic before, couldn't find a direct answer. Right now i have a DIY manual boost controller on my car. Have it set for 9 lbs. However, 1st gear will not hit 9 lbs. 2cnd and 3rd gear will hit it, but fall back down to 5 lbs rather quickly. Could this be a boost leak? If so, why would it stay at 5, but fall down from 9?
Turbo is a T3 .42/.48 on a single cam vtec. Let me know thanx
Old Apr 10, 2005 | 04:58 PM
hunderpressure's Avatar
Default Re: Loosing boost? (0ptimus Prime)
It sounds as if you have a massive leak some where in on your plumbing. I would think you should be hearing the air leaking.
Recheck all flanges on your piping for leaks paying particular attention to those on the exhaust flanges before the turbine and the one on the compressor discharge that bolts directly to the compressor. If no leak is found check your hoses for loose connection.
Old Apr 10, 2005 | 06:41 PM
hmmm i know i have a small leak at one of the intercooler pipes...but would that make it drop so dramatically?
Old Apr 10, 2005 | 06:46 PM
It sure would. That probarbly explains why you would get your boost fluctuating at different speeds, depending on the engine load which determines the flow through the turbine.
The leak would also give you boost spikes.
yessewey
Feb 19, 2010 08:50 AM
crvtkllr
Dec 24, 2008 02:50 PM
Po0r LiTTle CoUpe
Oct 15, 2005 10:39 PM
honkey2fly
May 15, 2004 10:32 AM
Ivan
Sep 20, 2002 10:39 AM
