LOOKING FOR 500HP BUT........
Old Oct 10, 2012 | 12:19 PM
kidn1980's Avatar
Icon7 LOOKING FOR 500HP BUT........
Like the title says i would like to reach or make a 500hp goal now the thing i am not starting new i already have some things but i know i need more but not too sure. any advice would be really appreciated and also pics as well. Here is what i know i have, b20b block, b18vtec head and b16 tranny, and i believe a 50trim turbo w/ front mount intercooler, 450 injectors, skunk 2 intake manifold.Don't know what brain i have, all i know its in clear case.
now i was advised to get an ls block, should i still buy an ls block or just sleeve the one i have.
Old Oct 10, 2012 | 12:32 PM
TheShodan's Avatar
Moderator
Default Re: LOOKING FOR 500HP BUT........
You're not even close with this equipment. You need to either sleeve the block, (possibly the CNC WERX as an alternative if you feel you're willing).
-Aftermarket pistons and rods, a real LSD (like a Quaife, Wavetrac , or MFactory Helical LSD)
-A 600hp capable intercooler
-Minimum 750cc injectors - Lots of sizes above are available.
-Fuel pump of Walboro255lph or larger
-Engine management that is not just some "chipped ECU", with a competent tuner
-53lbs/min or larger turbocharger, understanding what fuel you need to do it.
That's as much as I'll start you off with. the rest, you need to check out yourself.
Good Luck.
Old Oct 10, 2012 | 01:24 PM
Critikul's Avatar
Do you have a budget? Youre talking about many thousands of dollars, just FYI.
Old Oct 10, 2012 | 02:13 PM
jdmadam's Avatar
You need to do alot more searching and reading.
Here is a good start---> http://www.evans-tuning.com/support/...arts/b-series/
Old Oct 10, 2012 | 06:45 PM
foedoeswag's Avatar
I've found from the last ten years of building Hondas, the best form of advice is to read. My advice is to sit down with a computer and just read and research
Old Oct 10, 2012 | 07:04 PM
CDecker0218's Avatar
Why not bump up to a gt3076r?
Old Oct 10, 2012 | 07:10 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Why is it all these new people always want high hp?
spoolin_crx_'s Avatar
Take it from me im a good example...i should have done more research than i did. It would of saved me money.
Old Oct 10, 2012 | 08:42 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Never fear, for N3va3va is here!!!
DC2_117
May 6, 2013 10:42 PM
hatchboy
Feb 26, 2007 11:50 PM
rtnlsltn
Dec 29, 2006 02:01 PM
Topdawgg
Oct 4, 2005 06:27 AM
