1/2" oil drain diameter.
Old Oct 4, 2012 | 11:26 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default 1/2" oil drain diameter.
Is it sufficient for a BB Garrett?
Old Oct 4, 2012 | 11:50 AM
skateboard_ej8's Avatar
im hench irl
Default Re: 1/2" oil drain diameter.
Yes, just make sure you have no kinks or 90 degree fittings.
Old Oct 5, 2012 | 09:00 AM
Great. It will be a hard line, no kinks.
Old Oct 5, 2012 | 11:12 AM
dpetro1's Avatar
you'd be better off with 5/8" or -10 AN
Old Oct 5, 2012 | 11:50 AM
I know that 10an would be better. The question was if the 8an was sufficient enough. I have 8an fittings, flanges and tubing already laying around.
Old Oct 5, 2012 | 12:22 PM
TKERacer619's Avatar
If you have anything but a cast manifold skip the hard line. It will most likely fail prematurely.
Go with a braided -10an.
If there is any flex the AN flare will rip on a hard line. If its a tubular manifold it will flex. Cast you are all good. At least now I have an AN flare tool
Old Oct 5, 2012 | 07:53 PM
dpetro1's Avatar
lol, you know the proper size but come on and ask if you can use something smaller. sounds like you've already made up you're mind before posting
your question was vague anyways. can you define "sufficient enough"? yeah it will drain oil out of your turbo but how long until you come back on with a "why is my turbo smoking" thread. just run -10 like 99.9% of turbo honda's
Old Oct 5, 2012 | 10:40 PM
it is a cast manifold (edelbrock).
no, i don't know the "proper" size, but it doesn't take a genius to realise that a bigger diameter tube is superiour to the smaller diameter when relying on gravity for flow. my question was "is what i have laying around SUFFICIENT for proper operation?" the oil will either drain faster than the feed line supplies it, or it won't, it's not magic. i am sure there are people that have experience with both diameters to offer some insight. i'd rather not spend more money for marginal improvement.
Old Oct 6, 2012 | 03:16 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Tubing is based on OD while hose is based on ID...
Old Oct 6, 2012 | 07:49 AM
sure, i have .5 aluminium tubing and 8AN tube flares and nuts
Old Oct 10, 2012 | 09:26 PM
i realised that you mean there is a discrepancy between the cross-section of a tube and a hose. but i believe the tubing i have is oversized to yield -8 ID diameter.
Old Oct 11, 2012 | 03:07 AM
blackeg's Avatar
Honestly go bigger if u can its not worth the risk of smoking or whatever.
I've run that half inch on a sohc setup no smoke, but also tried it on a 2L vtec and it did smoke. I eventually changed to a 5/8 and it noticeably cut down on smoking
R.A.T.
Aug 16, 2009 07:07 AM
Topdawgg
May 25, 2007 08:20 AM
i3oricua
Apr 28, 2004 10:38 AM
VisualAutoMotoring
Jun 17, 2003 08:29 PM
