locktite on studs?
Old Feb 25, 2004 | 09:24 PM
redboost10's Avatar
Default locktite on studs?
would it be a good idea to use thread lock or whatever when installing those two studs in the head that are in the tight places when using a equal length manifold?
Old Feb 25, 2004 | 09:34 PM
Quik Chris's Avatar
Default Re: locktite on studs? (tgh99si)
I supose you could, but I think that the excessive heat (exh. manifold flange is the hottest part of the car, esp. on a turbo car) would negate any advantage that it would provide. I'll stick w/ spraying them w/ WD40 and calling it good.
Old Feb 25, 2004 | 10:18 PM
redboost10's Avatar
Default Re: locktite on studs? (Quik Chris)
i mean, would you use thread lock to put those two studs in the head, like for the sst manifold?
Old Feb 26, 2004 | 02:37 AM
swlabhot's Avatar
It would go up in smokes and burn right off so no point really.
Old Feb 26, 2004 | 04:24 AM
GDM Z28's Avatar
Default Re: locktite on studs? (swlabhot)
i used locktite on my car plenty of times and it always melts off . if you read the back it says its only good up to about 250 degrees F so therefore it wont work.
Old Feb 26, 2004 | 07:24 AM
BoostedSi's Avatar
Default Re: locktite on studs? (civicflnum1)
Yup, i used it once and that was it. It just burned off. Didnt do ****
Old Feb 26, 2004 | 07:51 AM
redboost10's Avatar
Default Re: locktite on studs? (BoostedSi)
alright thanks guys, a couple days ago i thought i read something about with the sst, get those two studes for those two tight places and just use some thread lock to put them into the head, nevermind that idea, thank you
Old Feb 26, 2004 | 09:26 AM
phiberoptik's Avatar
what are exhaust manifold studs supposed to be torqued to??
Old Feb 26, 2004 | 09:40 AM
GRTechnologies's Avatar
i always use thread lock on any turbo mainflod nuts for some reason 1 or 2 always back off
Old Feb 26, 2004 | 10:53 AM
IN VTEC's Avatar
I've always wondered what Honda uses on the manifold studs. Whatever it is, it works pretty damn well.
Old Feb 26, 2004 | 10:54 AM
redboost10's Avatar
Default Re: locktite on studs? (IN VTEC)
yeah, thats what i was thinking, i was gonna use the two on my b16a2 and move them to the two top end holes and then use the bolts in the two far side holes but i couldnt get those damn things out.
so thats why i was wondering would it be a good idea using it in the two aftermarket studs going into the head, if it burns then it burns, oh well
Old Feb 26, 2004 | 11:59 AM
what is the torque specs on manifold studs in the head?
Old Feb 26, 2004 | 12:30 PM
FredoSP's Avatar
interesting, I'd like to know too.
Old Feb 26, 2004 | 12:42 PM
ProEater's Avatar
Default Re: (phiberoptik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phiberoptik &raquo;</TD></TR><TR><TD CLASS="quote">what is the torque specs on manifold studs in the head?</TD></TR></TABLE>
i may be wrong but i thought it was 23lbs????!
Old Feb 26, 2004 | 01:25 PM
NyQuiL's Avatar
Default Re: locktite on studs? (FredoSP)
bump good question
Old Feb 27, 2004 | 06:59 AM
bump for torque specs on exhaust manifold studs
Old Feb 27, 2004 | 07:26 AM
dasher's Avatar
For the B18C1 the self locking nuts should be torqued down to 23 ft/lbs
BongoBennie
Engine Machining & Assembly
Jan 29, 2017 07:50 PM
Snailor Built
Aug 31, 2013 06:46 AM
Cestparti
Sep 3, 2010 06:45 AM
99_EM1
Feb 8, 2010 06:03 PM
vestalfootball72
Mar 30, 2007 08:31 AM
