Liquid-to-Air Intercooler Question?
Old Feb 15, 2005 | 04:00 PM
The G2 Racer's Avatar
Default Liquid-to-Air Intercooler Question?
Had a quicl question about liquid to air intercoolers. What can you fill them with? I know you can use water but then wouldn't it heat up in the summer and freeze in the winter?
Is there a liquid you can use in them all year around?
Also I'm guessing you need to hook the lines up to a pump and a tank to drain and pump the 'cooling' liquid through the intercooler correct?
Old Feb 15, 2005 | 04:05 PM
b18bturbo's Avatar
Default Re: Liquid-to-Air Intercooler Question? (The G2 Racer)
You can use additive such as redline water wetter or royal purple cool burst. both can be added in the system ot provide the added protection . If you can also mix a little anti freeze in the setup as well Just water cooler like any old radiator
you should have setup such as this
resovoir- pump - lines to intercooler output line goes to heat exchanger then back to the pump/resovoir container
Old Feb 15, 2005 | 05:08 PM
Default Re: Liquid-to-Air Intercooler Question? (b18bturbo)
Now for a heat exchanger, could you just use one of those tranny cooler things they sell at part stores?
gsrt
Dec 13, 2012 07:49 AM
B18c1turboedEK
Jan 24, 2011 02:38 PM
ScottEK
Jul 20, 2004 10:19 AM
Sinner
Mar 24, 2004 05:07 AM
TurboTeG4
Sep 27, 2003 10:51 PM
