lowering CR without pistons ??????
Old Dec 24, 2004 | 09:03 AM
jfboy's Avatar
Default lowering CR without pistons ??????
is there a good way to lowere you compression ratio witout using pistons on the ls motor ????(ie: like a custom head gasket)
Old Dec 24, 2004 | 09:09 AM
b18bturbo's Avatar
Default Re: lowering CR without pistons ?????? (jfboy)
you can order your self up a cometic .054 gasket or .063 MLS gasket to drop compression but really there is no need to drop any compression on a LS motor
Old Dec 24, 2004 | 09:18 AM
Hyaboosta's Avatar
Default Re: lowering CR without pistons ?????? (b18bturbo)
I have hear of people putting larger cosmetic gaskets on and even some people using arp head studs to hold it down and 2 oem gaskets on top of each other. but LS compession is already low enough
Old Dec 24, 2004 | 07:28 PM
jfboy's Avatar
Default Re: lowering CR without pistons ?????? (Hyaboosta)
2 head gaskets.... hmmmm sounds risquy ????? where can I get a the .63 head gasket ???? How think is the oem BTW ???
Old Dec 24, 2004 | 07:35 PM
mrbsponge's Avatar
look to inline pro, they have what you are looking for
Old Dec 25, 2004 | 07:22 AM
hondaapi's Avatar
Default Re: (mrbsponge)
Here in Germany a lot of people lower theire compression ratio wit a metal plate between two head gaskets.
Here it is very commen and to get for just a little money and proven also.
The few guys here that run turbo on Honda (VW is much more commen) run really low CR (round 7.5 - 9).
The main reason seems to be that pistons are not easy to get and we have to import the most parts.
Old Dec 25, 2004 | 09:04 AM
jfboy's Avatar
Default Re: (hondaapi)
do you have a link showing that (the metal shim the can be sandwiched between two gaskets)????
Old Dec 25, 2004 | 09:12 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: (jfboy)
Inline Pro
Old Dec 25, 2004 | 09:39 PM
jfboy's Avatar
Default Re: (Stunna BEN)
website???
Old Dec 25, 2004 | 11:18 PM
PrettyLude's Avatar
http://www.inlinepro.com
Old Dec 26, 2004 | 05:32 AM
b18bturbo's Avatar
Default Re: (PrettyLude)
yup the inline gaskets have been proven time after time some people sayit just like a cometic but not 100% sure
Old Dec 26, 2004 | 09:05 AM
jfboy's Avatar
Default Re: (b18bturbo)
200$ for a head gasket now those 500$ pistons dont sound so bad.....
Old Dec 26, 2004 | 09:27 AM
TheShodan's Avatar
Moderator
Default Re: (jfboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfboy &raquo;</TD></TR><TR><TD CLASS="quote">200$ for a head gasket now those 500$ pistons dont sound so bad.....</TD></TR></TABLE>
But why lower an LS? What's your point?
Old Dec 27, 2004 | 12:33 AM
hondaapi's Avatar
Default Re: (TheShodan)
I donīt have a link for that, but if you give me your E-mail I can send you a picture. I and some friends of me used that way of lowering CR sixtimes and had never any problems. In so far, that a fiend of mine works at a CNC company and we have the program on PC it is very cheap for us. In dollars just roundabout 50USD.
Old Dec 27, 2004 | 10:09 AM
AzG35's Avatar
The gaskets from InlinePro are very similar to the Cometic ones. I am running a .074 cometic in my motor and haven't had any problems at all. Lowers the CR about 1.5 points. You should need anything that big though.
jdmcivic904
Mar 1, 2011 06:49 PM
vajdmeg
Jan 30, 2009 11:01 AM
NathanMorris
Jul 28, 2006 05:59 PM
vtekthis
Nov 2, 2004 07:17 PM
TypeR1558
Aug 7, 2001 02:03 PM
