Lets try this again.
Old Feb 27, 2002 | 04:33 PM
  #26
DRAGLS's Avatar
Default Re: Lets try this again. (TurboMiata)
actually my egt's run at 740c the most before the turbo.
Old Feb 27, 2002 | 04:36 PM
  #27
TurboMiata's Avatar
Default Re: Lets try this again. (DRAGLS)
sorry haltech is the way to go
This could get really long, so I'll just say "I hope your getting an upgraded ignition with your haltech. The TEC comes with one integrated...."
Old Feb 27, 2002 | 04:40 PM
  #28
i 4's Avatar
i 4
Oh yeah, upgrade the ignition and run stock spark gap. You'll see a more complete burn. You will have less knock, and can run more ignition advance for more HP. fwiw......
stock honda ignition works perfect, no need for upgrade there at all.
Old Feb 27, 2002 | 04:42 PM
  #29
i 4's Avatar
i 4
my haltech made me very happy.
Old Feb 27, 2002 | 04:44 PM
  #30
TurboMiata's Avatar
Default Re: Lets try this again. (i 4)
Stock honda ignition works perfect, no need for upgrade there at all.
If this were true, you could run larger spark plug gap without misfire. With the plug gap he is running, it isnt true......
Old Feb 27, 2002 | 04:45 PM
  #31
LsTurbo91's Avatar
whats your timing like at 14lbs of boost at around 5000rpm?
Old Feb 27, 2002 | 05:12 PM
  #32
i 4's Avatar
i 4
i can name a couple of b-series making 450+whp with stock ignition( they never miss fire, never), they have no need for an ignition upgrade. I understand your point, there's just not any problems with the stock ignition.
[Modified by i 4, 9:18 PM 2/27/2002]
Old Feb 27, 2002 | 07:07 PM
  #33
HXMan's Avatar
Did they ever think an aftermarket ignition could make more power at the high boost levels they must be running? Just because they never missfire, dosen't mean an aftermarket ignition wouldn't be better. If I spent all the money to get a honda block to handle 450+ whp, I would definitly invest in an ignition upgrade.
[Modified by HXMan, 10:07 PM 2/27/2002]
Old Feb 27, 2002 | 07:16 PM
  #34
TurboMiata's Avatar
Default Re: Lets try this again. (HXMan)
Just because they are making that much HP doesnt mean that they couldnt make more with a stronger, longer duration spark. The more complete the spark, the less "unburnt crap" will be left over to burn in the exhuast (right before the turbo)
Lower EGT's, thus more ignition advance via the ol standalone until MBT is reached. Just because they are making that much HP doesnt mean there isnt room for improvement...... The stock Honda ignition wasnt designed to handle that much boost. If it were then our friend here with the LS would be running .40 or .60 or whatever stock gap is and not the little .2x he is now.....
Old Feb 28, 2002 | 01:51 PM
  #35
DRAGLS's Avatar
Default Re: Lets try this again. (LsTurbo91)
my timing is as follows:
800=+3
2400=+3
4000=+3
5600= -1
7200= -1
d15bfi
Sep 14, 2010 07:16 PM
99lspwr
Oct 14, 2006 10:25 AM
deez nuts
12
Jun 30, 2003 01:32 PM
Speed PHreak
Dec 16, 2002 07:04 PM
