leaning out?
Old Sep 3, 2002 | 09:39 PM
wrXtian's Avatar
Default leaning out?
well my car feels great w/ the boost... at half throttle that is.. but whenever i try to actually punch it on the freeway mainly i don't feel the boost anymore my car barely climbs it felt faster when it was N/A lol.. all i have is the vortech 12:1 fmu.. i'm guessing maybe cuz i dont' have a inline fuel pump? any suggestions??
Old Sep 3, 2002 | 09:46 PM
Mase's Avatar
Default Re: leaning out? (xjdm94x)
****, if you dont want a blown motor, id suggest not boostin until you get an inline pump
Old Sep 3, 2002 | 09:47 PM
Kamin's Avatar
Default Re: leaning out? (CDooMe2)
um yea
you NEED AN INLINE
you will blow your **** up.
Old Sep 3, 2002 | 09:49 PM
wrXtian's Avatar
Default Re: leaning out? (KAMiN)
i just bought it today and am installing it 2m morning.. i was just curious if that was my problem
Old Sep 3, 2002 | 10:45 PM
rjardy's Avatar
YES YES YES that is your problem, an FMU requires more pressure to opperate correctly, more than your stock intank, or evan an aftermarket intank can provide.
Rob
Old Sep 4, 2002 | 09:24 PM
wrXtian's Avatar
Default Re: leaning out? (rjardy)
ok.. well i installed my inline and i have my vortech 12:1 fmu and i'm still leaning out!!! any suggestions guys? u think maybe 2 much boost? injectors r messed up?? any suggestions would help.
thanks
Old Sep 4, 2002 | 09:30 PM
ELUD THS's Avatar
New User
hmm thats weird. i had the exact same problem as you befroe my inline pump, but aftre the install i was staying rich in 5th gear. try checking to see if you ran the inline pump right. make sure you have a relay attached to it as well.
Old Sep 4, 2002 | 09:32 PM
wrXtian's Avatar
Default Re: leaning out? (ELUD THS)
i think i got it all right.. have the hoses plugged in right.. a 12v power.. and a ground..
Old Sep 4, 2002 | 09:37 PM
ELUD THS's Avatar
New User
what car is this for and what is your setup. im running 7 psi on a 5th gen lude., i was leaning out in fifth gear with my stock fuel pump and a FMU,. boosted a little that day to try out because the stock fuel pump on a prelude can hold 7psi if you dont over kill. tried taking it on the highway and it leaned out in fifth gear, figureed out my prob. slapped a inline pump and started riching in 5th. the only other suggestion that i can offer is if you have the inline connected properly and your still leaning in 5th gear, id say check your check valves make sure your not throwing a code,. if all your lines are hooked up correctly you should be in rich, not stoich or lean in 5th gear boost. all depends on how much your boosting to, because if your running high boost you should consider some kind of stand alone. what injectors are you using? stock or 310's?
Old Sep 4, 2002 | 09:43 PM
wrXtian's Avatar
i'm running a 15g inside my 1990 integra.. i installed my check valves a couple days ago and i'm not getting a cel nemore.. so it seems like that fixed that problem.. i'm using stock injectors.. i'm unsure of my boost cuz i don't have a boost guage yet but the previous owner said it was set to 5.. it's the greddy 15g w/ a built in wastegate..
Old Sep 4, 2002 | 09:51 PM
ELUD THS's Avatar
New User
that could be your problem, your stock injectors might need to be cleaned and balanced., your not releasing enouhg fuel in 5th gear and your FMU is trying to gte more fuel outta your inline and your pump, and your pushing to much pressure for the stock injectors to handle.
Old Sep 4, 2002 | 10:53 PM
wrXtian's Avatar
well i don't know if this would effect anything.. but my vortech fmu is mounted upside down cuz i couldn't really get it to fit somewhere else the rite side up.. i duno if that would make a difference?
Old Sep 4, 2002 | 10:57 PM
quickspoolin's Avatar
Make sure injectors are clean and make sure that fmu is really 12:1 .
Old Sep 4, 2002 | 10:58 PM
wrXtian's Avatar
Default Re: leaning out? (quickspoolin)
how can u check to see if a fmu is a 12:1?
Old Sep 5, 2002 | 02:32 AM
niedejb's Avatar
On a 12:1 the disc its as big as the diameter of the FMU. I run a 4:1 and its only 1" or so in diameter.
Old Sep 5, 2002 | 03:26 PM
wrXtian's Avatar
Default Re: leaning out? (niedejb)
any other suggestions??
Old Sep 5, 2002 | 03:32 PM
accordfreak's Avatar
while we're on the topic, would running 310 injectors, inline pump, stock intank, stock fpr, and 12:1 fmu be too much fuel??
Old Sep 7, 2002 | 07:32 PM
wrXtian's Avatar
Default Re: leaning out? (accordfreak)
i got a suggestion that the fmu might be stuck?? can anyone help me out on this one.. don't quite understand what they mean by stuck.. how can i fix this problem if it is the problem?
thanks
Old Sep 8, 2002 | 07:17 PM
wrXtian's Avatar
ttt
Old Sep 8, 2002 | 07:37 PM
SIK IN DA HED's Avatar
New User
too rich. get a 8:1 rate.
YellowPhoenix095
May 14, 2007 06:30 AM
civic dx
Nov 27, 2004 03:08 PM
steroidguy
Nov 20, 2003 03:43 PM
cjames235
Aug 17, 2002 01:18 AM
