leakyoil separator box!!!
Old Dec 19, 2003 | 02:43 PM
2K Teggy's Avatar
Default leakyoil separator box!!!
I have a JRSC 2000 GSR with 6psi. The damn oil separator box keeps leaking. I have rigged a little and used a fatter o ring gasket as a bandaid and it works for like a few months. But then I get that damn oil smell not too long after. I figured the stock O ring gasket wouldn't be good enough but I could be wrong. JRSC doesn't alow me to use the bracket that is supposed to help hold the damn thing on. That bracket was useable with the stock intake manifold but not this set up. What have you other JRSC guys done to yours or do you even have this problem? The oil separator box seems as it is forced on there and tight as hell yet it slowly leaks, my oil level stays fine, but that is very annoying when I start to smell oil. Do I perhaps need an oil catch can? Can I use that bracket? I've tried but damn there is like no room behind the damn engine block at all since blower install.
Thanks for anybody who can help.
Old Dec 19, 2003 | 05:25 PM
Jared's Avatar
Default Re: leakyoil separator box!!! (2K Teggy)
is your pcv valve clogged?
Old Dec 20, 2003 | 10:09 AM
JforJonathan's Avatar
damn this, damn that.................damn
dupes4lyfe
Dec 9, 2013 08:30 AM
LitlGuy
Nov 8, 2007 09:06 PM
spidermancivic
Jun 19, 2005 08:57 AM
