Kpro on AP1 - Datalog wideband using ELD
Old Jul 26, 2011 | 08:46 AM
sp00led's Avatar
Default Kpro on AP1 - Datalog wideband using ELD
I need to datalog my wideband within Kpro. I was told I can do this using the white wire on my AEM wideband and pinning it to the ELD in my AP1 harness.
After I do this what needs to be done in Kpro in order to datalog the wideband? Has anyone set this up before or seen a thread that shows the process?
Looks like the ELD is pin 30 on the harness. What type of pins does the RSX/S2000 use. Can I use pins from an old integra harness?
Old Jul 26, 2011 | 09:11 AM
q16racer's Avatar
Default Re: Kpro on AP1 - Datalog wideband using ELD
disable ELD
tell kpro where to look for wideband.
Old Jul 26, 2011 | 10:41 AM
sp00led's Avatar
Options then Settings pulls up the following screen shot. Anyone know what values should be entered for the AEM wideband? It is not listed on the pull down menu as an option.
Old Jul 26, 2011 | 12:29 PM
SovXietday's Avatar
0 should be 10
5 should be 20
It may have a slight voltage offset, you will be able to see this by turning the ignition on and letting the wideband go all the way lean. Look at the voltage that the ECU is seeing and subtract that from 5. Walla, offset.
Old Jul 26, 2011 | 03:49 PM
sp00led's Avatar
Thanks!
641iowaguy641
May 14, 2013 06:17 PM
Boosted_01 R
Engine Management and Tuning
Jul 28, 2012 10:35 AM
LudeLooker
Apr 7, 2008 05:17 PM
tepid1
Oct 2, 2007 01:18 PM
AP2S2K
Honda S2000
May 2, 2007 10:32 AM
