Kit almost complete, anything I'm missing?
Old Mar 11, 2006 | 09:09 AM
SiR Mikey's Avatar
Default Kit almost complete, anything I'm missing?
Well, I'm a month or so away from boosting, and wanted to know if there is anything you guys would recommend improving on/replacing.
Set-up (in the car currently)
Stock LS block (112k on it)
-New water pump
-New timing belt
96 GSR head
Type intake cam
GSR exhaust cam
Skunk 2 intake manifold
Type R throttle body
B&M fuel pressure regulator
Turbo set up (in the garage )
Precision SC60 57 trim .60 ar
Rev hard log manifold
Tial 38mm wastegate
Crushed DSM bov
2" turbo-IC pipes
2.5" intercooler to tb pipes
20x8x3.5 bar and plate intercooler
DSM 440 injectors
2.5" downpipe
Oil feed/return line
Steward warner boost gauge
Colder spark plugs
Autometer fuel and oil pressure gauges
Wideband o2 (going to order)
Walbro 255 fuel pum
Dynotuned with NepTune @ 10psi
Would you guys say thats a safe set up for daily driving? Any areas I could improve on? #'s I should be looking to see out of it. I'm going to throw in a set of rods/rod bolts shortly down the road, as well as a 6 puck when I put the LSD in.
Thanks in advance
Old Mar 11, 2006 | 09:11 AM
B18 CYA's Avatar
oil feed line, oil return line, thats about it from what it looks like that you'll also need.
Old Mar 11, 2006 | 09:14 AM
SiR Mikey's Avatar
Default Re: (B18 CYA)
I've got all that too, just trying to see if theres anything big I'm missing
Old Mar 11, 2006 | 10:12 AM
VI Boost's Avatar
Default Re: (blacklil91)
that looks just about right...
Old Mar 11, 2006 | 10:18 AM
Schister66's Avatar
Man U FTW
personally i would go w/ some 550s......
Old Mar 11, 2006 | 12:04 PM
SiR Mikey's Avatar
Default Re: (Schister66)
I plan on it as soon as I can(money is getting tight), but for the price of these I couldn't pass them up
rhdune16
May 6, 2005 11:10 AM
civproject14
13
Nov 14, 2004 07:29 AM
projectTeG
Jun 20, 2004 07:34 AM
RATEDR
Aug 27, 2002 10:24 AM
RATEDR
Aug 25, 2002 10:37 AM
