just got back from the track :(
Old Apr 22, 2003 | 06:58 PM
turbod16y8's Avatar
Default just got back from the track :(
i need your help guys. went to the track today. was stagging and yellow yellow yellow launcheddd and then CraCk.. something broke. just got home and took the tires off. now when i spin the tires it makes a knocking sound. i just installed a clutch and flywheel like a week ago. when i spin the passenger side wheel, sometimes the other side would spin and sometime it doesnt. when it doesnt spin it makesa grinding sound. what do you think it is?
Old Apr 22, 2003 | 07:03 PM
98civicEX's Avatar
Default Re: just got back from the track :( (turbod16y8)
don't be too sad, you broke and axle....go to autozone or discount auto it's a 50 core, then invest in some DSS axles.
Old Apr 22, 2003 | 07:07 PM
qqqq
Guest
Posts: n/a
yea dont worry it is a axle. plan on changing these alot being turbo charged unless you invest in some good ones.
Old Apr 22, 2003 | 07:43 PM
turbod16y8's Avatar
Default Re: just got back from the track :( (babyboib16)
how do i know if its the axles? what do i check on them? i just got both of them off
Old Apr 22, 2003 | 08:36 PM
turbod16y8's Avatar
ok the axles are fine....this one guy told me it might be my differential. so i guess im taking the tranny off and taking my POS centerforce dual friction i just put on there 3 days ago.... which clutch should i go with>? ACT hdss or xtss? right now im running 9 psi and in the future planning on 15. thanks
Old Apr 22, 2003 | 08:48 PM
98civicEX's Avatar
XTSS, saying that because i have it in my car, and it holds fine....doesn't slip at all..and grips just as good as the slicks
Old Apr 22, 2003 | 09:00 PM
UberTeg's Avatar
stock pp with clutchnet stage 2 is holding my power just fine I'm running 11 psi.
Old Apr 22, 2003 | 09:02 PM
Teg4e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbod16y8 &raquo;</TD></TR><TR><TD CLASS="quote">ok the axles are fine....this one guy told me it might be my differential. so i guess im taking the tranny off and taking my POS centerforce dual friction i just put on there 3 days ago.... which clutch should i go with&gt;? ACT hdss or xtss? right now im running 9 psi and in the future planning on 15. thanks</TD></TR></TABLE>
i'm lookin to run about 15psi and have 300whp on my LS, and i plan on running the XTSS. I heard it holds up to 310 or so lb-ft.
Old Apr 22, 2003 | 09:06 PM
Mase's Avatar
just curious, why didnt you break in your clutch?
Old Apr 22, 2003 | 09:09 PM
DIRep972's Avatar
Smarter than you
Default Re: just got back from the track :( (UberTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UberTeg &raquo;</TD></TR><TR><TD CLASS="quote">stock pp with clutchnet stage 2 is holding my power just fine I'm running 11 psi.</TD></TR></TABLE>
on a T25.
Old Apr 22, 2003 | 09:48 PM
Teg4e's Avatar
Default Re: just got back from the track :( (IRepD)
clutchnet stage 2 holds pretty strong (supposedly up to 300lb of tq), but otherwise the clutch sucks. chatters, terrible pedal feel, squeaks....
Old Apr 22, 2003 | 11:36 PM
UberTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IRepD &raquo;</TD></TR><TR><TD CLASS="quote">
on a T25. </TD></TR></TABLE>
T25 powa ownz jo0 biatch
Old Apr 23, 2003 | 05:37 AM
Snail Tuning's Avatar
did u break the clutch in also if its not making noise when the gears are engaged it might not be your clutch id get your differential looked at
Old Apr 23, 2003 | 09:44 AM
turbod16y8's Avatar
Default Re: just got back from the track :( (bmcc72)
the clutch aws broken in.... and yea i think its my differential.. how do i get this fix? how much? is it hard to do myself? im dropping the tranyy today i hope...
Old Apr 23, 2003 | 10:17 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbod16y8 &raquo;</TD></TR><TR><TD CLASS="quote">the clutch aws broken in.... and yea i think its my differential.. how do i get this fix? how much? is it hard to do myself? im dropping the tranyy today i hope...</TD></TR></TABLE>
Honestly, just buy another tranny. $200 and viola.. no differential problems
lilo_goki
16
Apr 14, 2008 11:08 AM
prison_snitch
10
Jul 4, 2006 12:55 PM
Accord94DX
28
Oct 8, 2003 06:34 PM
egracer44
Aug 9, 2003 12:11 PM
hybrid901
Jun 3, 2002 11:42 AM
