Just got back from the dyno...
Old Jul 17, 2002 | 01:30 PM
JM Performance's Avatar
Default Just got back from the dyno...
I just got back from DRT in NYC. We dyno tuned my turboed LS teg w/ MF2 and BTM. As you can see the results turned out pretty good.
Also, check out what I wrote below:
my torque numbers look good, but does anyone know why they're dying off so much (like 25lbs) up top. I think I could make a lot more horse power if I would pull up my high end torque) if I could make 185ft/lbs at redline I'd be making 240hp. could it be the T04B/T3?
Heres my car on the dyno:
Heres the plot (the two runs are at 6psi and 9 psi):
Oh, and as you all can see, the MF2 does work.
[Modified by 00SilverLS, 5:31 PM 7/17/2002]
[Modified by 00SilverLS, 6:13 PM 7/17/2002]
[Modified by 00SilverLS, 6:47 PM 7/17/2002]
[Modified by 00SilverLS, 6:54 PM 7/17/2002]
Old Jul 17, 2002 | 01:34 PM
safe driver's Avatar
Default Re: Just got back from the dyno... (00SilverLS)
is that detonation i see between 6k - 7k ???
Old Jul 17, 2002 | 01:36 PM
C-Murdock's Avatar
looks good for an LS man, how does the car run ?
I thought the numbers would be higher seeing how LS's respond well to boost.....
Old Jul 17, 2002 | 01:39 PM
Default Re: Just got back from the dyno... (safe driver)
dont think so...there was no audible pinging and the fuel was at 12.3 across the board, except for around 4.5-5.5 were it was richened up a bit for safety.
Old Jul 17, 2002 | 01:41 PM
Tomakit's Avatar
Looks good.
Tom
Old Jul 17, 2002 | 01:45 PM
Default Re: Just got back from the dyno... (Tomakit)
EDIT: yeah, if I could make 185ft/lbs at redline I'd be making 240hp.
[Modified by 00SilverLS, 5:47 PM 7/17/2002]
Old Jul 17, 2002 | 01:48 PM
ceemarun's Avatar
how much were you boosting? and was your ignition stock or retarded?
edit: nm, just read
[Modified by ceemarun, 10:51 PM 7/17/2002]
Old Jul 17, 2002 | 02:00 PM
shadowdawn's Avatar
Default Re: Just got back from the dyno... (ceemarun)
Congrats matt Nice numbers, glad the mf2 is working out for you.
Old Jul 17, 2002 | 02:07 PM
SpeedMonkeyRacing's Avatar
Default Re: Just got back from the dyno... (shadowdawn)
i was there...was suprirse to see 205/190 on one fo the run...
so to those who think mf2 doesn't work
too bad i went bigger everything and got hondata...think i'm use the mf2 on my crx
Jeff-
ef9robert
Southern California
Oct 29, 2008 03:37 PM
dynamyks
Jun 15, 2005 06:02 AM
stevecockrill
Aug 21, 2002 02:21 PM
