Just bought a turbo...question.
Old Aug 16, 2002 | 02:23 PM
KC GSR's Avatar
Default Just bought a turbo...question.
Hey guys, I just bought a used turbo in good shape for a good price. The only problem is it's the small t3 (.48 A/R on exhaust side, .42 on compressor side). My question is, it seems the status quo for most daily driven cars is around 7psi. I know the drag kits come with t3/t4s so does that mean since i'm running a much smaller turbo, I can run a bit more boost on my stock gsr motor? I got tired of waiting to find a great deal on a good sized t3 or hybrid so I just took this one while I could. Again, my question is can I run higher boost to make up the difference in turbo size? I will be running the vafc hack + dsm injectors and dont know if the -35% low -40% across setting will be too rich for this little turbo at only 7psi. Any info would be great, thanks!
Old Aug 16, 2002 | 03:18 PM
rjardy's Avatar
Default Re: Just bought a turbo...question. (KC GSR)
the reason for a larger turbo would be volumetric effieciency not more boost.
Rob
Old Aug 16, 2002 | 08:31 PM
KC GSR's Avatar
Default Re: Just bought a turbo...question. (rjardy)
OK, so does that mean that 7psi from a smaller turbo will produce the same hp numbers as 7psi from a larger turbo? Thanks for the response btw.
Old Aug 16, 2002 | 08:33 PM
Mase's Avatar
not really..... remember hi pressure, low flow and low pressure, high flow
Old Aug 16, 2002 | 08:42 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Just bought a turbo...question. (CDooMe2)
be carefull setting boost levels others are running with bigger AR's, even at 7PSI you will be pushing that turbo at the higher end of the efficiency map, the charge temperature will be higher and you will have more chances of detonation.
Old Aug 16, 2002 | 08:59 PM
KC GSR's Avatar
Default Re: Just bought a turbo...question. (90crxsi)
Doh well i suppose if worse comes to worse I can use that one until I can find one I *really* want
Old Aug 16, 2002 | 11:54 PM
Mase's Avatar
Go for it
Jeanious
Oct 11, 2008 05:02 PM
wade
Sep 15, 2004 03:20 PM
BlackB18CTeg
Aug 2, 2003 06:25 AM
buckfittyone
Jul 29, 2003 10:54 AM
LOwrestling2001
Nov 27, 2002 09:59 AM
