How involved is a nitrous install?
How many hours did this take you guys to install??
Is it pretty much straight forward? running the lines, tapping a hole in my CAI about 6in away from the Throttle body?
and, does anyone have a pic of the TPS from a b16a2? im not sure where i am going to put the Black wire for the Nitrous switch (ZEX kit), it says it goes to the TPS, i am guessing the red/white wires goto the switch then?
any info is appreciated !
thanks,
mike
p.s. in case you didn't catch it, this will be the ZEX kit
BTW: How much WHP should i be putting down with a 75 shot?
thanks again!
[Modified by MikeMAN, 8:12 AM 8/16/2002]
thanks,
mike
thanks again!
i have the nos system in my hatch it was pretty easy. putting all the "stuff together
took the longest. all in all i think it took us about 3 to 4 hrs to put it in.
3 hours here as well. Assembly of the solenoids took awhile. Also finding a way to run the line from the trunk to the front took some "creativity".
for the zex kit the first day we just ran the lines from the trunk to the engine bay took about an hour then the next day we installed the rest of the kit and took probbaly about 2.5 hours
running the line is as easy as running 4 guage amp wire and running the wire took me all of about 10 min in my teg so i dont think the line should take much longer
If you are running the zex kit, you want to tap that hole for the nozzle as far away from the TB as possible. This provides a more uniform mixture, and aids in the cooling of the intake charge. If you put it too close to the TB, the nitrous gets forced to the back of the intake manifold, and is not distributed evenly to all cylinders.
ZEX wiring,
black = ground
red = power
white = TPS
tap into the middle wire on the TPS
nozzle needs to be 16-18" from thottle body.
Next step, 12's
black = ground
red = power
white = TPS
Next step, 12's
