just boosted but won't run
like the title says I just boosted my car but it won't run. My setup is a BONE stock ls from the valve cover to oil pan. I gotta to4e with open downpipe and I'm running precision 780s. I'm using the tune from my last motor to try to start it. It was a ls-vtec with the same turbo kit but with 550s tuned at 12psi. When I started my car it fired right up the popped and shut off. I'm not sure what it could be besides being really rich. I'm getting a tune tomorrow but I would like to know if it could be anything else. Any input is apreciated. Thanks
moderator emeritus
Re: just boosted but won't run (boostedeg302)
the tune isnt setup for injectors that are 230cc larger. Likely causing the fuel to puddle and not allow the engine to idle properly.
Re: just boosted but won't run (98vtec)
thats what I was thinking but needed a second opinion. The way it fired right up makes me think that everything is hooked up right. It just sounds way rich
moderator emeritus
Re: (93supercoupe)
did you even read the first post?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe »</TD></TR><TR><TD CLASS="quote">first check for spark then move on to belt timing, then compression.</TD></TR></TABLE>
Re: (98vtec)
turn ur fuel pressure down to about 20 psi is possible just to get it to the dyno. at the dyno turn it back up to 40 psi. make sure u clean ur plugs out first
vtecsi00
03-05-2008 12:35 PM
lude98SH
05-11-2007 10:30 PM
