JUN Lightened Flywheel.
Old Oct 25, 2001 | 07:04 PM
B19CivicHB's Avatar
Default JUN Lightened Flywheel.
Hey fellas,
I just purchased a JUN lightened flywheel for my JDM B18C1 powered 92 hatchback. Was this a worthwhile buy? Will it sacrifice streetability? Ive never driven a car with a lightened flywheel so im not sure how the cars respond to them. Let me know, Thanks.
Old Oct 25, 2001 | 07:19 PM
PureTeg420's Avatar
Default Re: JUN Lightened Flywheel. (B18CivicHB)
is it the ultra light? or the regular? On the heavier of the two there's something wrong with the teeth and it can cause starter problems.
Old Oct 25, 2001 | 07:32 PM
B19CivicHB's Avatar
Default Re: JUN Lightened Flywheel. (PureTeg420)
its the one that weighs 4.4kg i believe.
Old Oct 25, 2001 | 08:01 PM
FAST94GSR's Avatar
New User
You won't have any problems. But you will have to rev it a little more to get the car to move off the line. The lack of weight reduces the inertia that was stored in your stock flywheel. You should be fine.
Old Oct 25, 2001 | 09:28 PM
B19CivicHB's Avatar
Default Re: JUN Lightened Flywheel. (FAST94GSR)
What are the advantages to the lightened flywheel then?
Old Oct 26, 2001 | 04:22 AM
jamal-188's Avatar
RPM's will rise much faster, resulty in increased acceleration. It will also be a bit tricky to get used to on hills.
Old Oct 26, 2001 | 06:59 AM
B19CivicHB's Avatar
Default Re: JUN Lightened Flywheel. (jamal-188)
How much will it mess with my daily driveablity? Im making a street car, not a drag car.
Old Oct 26, 2001 | 07:04 AM
rtype11's Avatar
revs drop faster between shifts, unless you stand on the pedal between shifts also
Old Oct 26, 2001 | 07:07 AM
B19CivicHB's Avatar
Default Re: JUN Lightened Flywheel. (rtype11)
So was it a mistake for me to pay all this cash for a JUN flywheel? grrr i still want to be able to comfortably daily drive the damn thing...
Old Oct 26, 2001 | 07:35 AM
dragonsmp's Avatar
New User
I will buy it if you want to sell it. Let me know
Old Oct 26, 2001 | 07:38 AM
VTECPWR's Avatar
Default Re: JUN Lightened Flywheel. (dragonsmp)
I have a 12lbs flywheel on my daily driver, and I drive in a lot of traffic with some big hills. My only complaint is that it is not light enough. I think you will be fine, it might take a little getting used to, but it is not too light.
Old Oct 26, 2001 | 08:06 AM
rtype11's Avatar
no not necassarily, dropping the clutch wont be as effective, the turbo technically spools slower as a result - just like in Gran Turismo, buy a lightened fly0 for a turbo car and try launching going uphill, the car wont start.
PS I think VTECPWR comments are from an NA point of view, there is no way he is turbo
Old Oct 26, 2001 | 09:36 AM
VTECPWR's Avatar
No, the turbo is not in yet, most of the parts are lying around the house. But it will hold the same once the car is turbo'd, I will still feel that the flywheel is not light enough. You have to rememeber there is a difference between a factory turbo's car and a factory NA car with a turbo added. If you start dropping your compression you might begin to have some driveability issues, but if you are stock I think it should be fine.
HondaH22A
Apr 24, 2003 05:34 AM
fire7882
Apr 25, 2002 02:16 AM
cccya
Mar 18, 2002 03:59 PM
DA666
Dec 27, 2001 07:37 AM
