JRSC question
Old Apr 2, 2003 | 06:34 PM
vtecman's Avatar
Default JRSC question
I installed the charger on my 99 civic si and it runs great but now my check engine light is on and it shows that my knock sensor is malfunctioning. I am running colder plugs, timing is retarded, and the light was not on before so I am curious why the light is on now. Did anyone have this problem when there charger was installed??
Thanks
Old Apr 2, 2003 | 07:14 PM
RacerXI's Avatar
Default Re: JRSC question (vtecman)
Try resetting it to see if it was a freak thing. I didn't have that problem with my car, but i'm running a hondata.
Old Apr 3, 2003 | 08:51 AM
Spunkster's Avatar
When installing the charger you may have either broken the sensor, or damaged the wires in the harness that connect to the sensor. The sensor is located right below the manifold near the stock alternator mounting location.
Old Apr 3, 2003 | 08:53 AM
RacerXI's Avatar
Default Re: JRSC question (Spunkster)
Check and make sure it's plug in also.
Old Apr 9, 2003 | 03:55 PM
vtecman's Avatar
I got under the car the other day and noticed that the wire was not in the connector for the knock sensor so i reinstalled the wire in the connector and plugged it back in. Then I pulled off the negative terminal and pulled the 15amp ecu fuse for 15 mins then reconnected the battery and fuse and the check engine light was off when i started the car but as soon as i got down my block the dam light came back on. I have no idea what to do now does anyone have any ideas??
They will be most appreciated.
Thanks a lot.
Old Apr 9, 2003 | 04:00 PM
greekspeed's Avatar
make sure u wired everything correctly (if u did it urself) and/or that the wiring u did do (or had done) is good well raped/taped so that the signals are being sent.
elliotEk
Honda Civic (2006 - 2015)
Jul 6, 2012 02:50 PM
Amped
Dec 16, 2007 01:58 PM
matthevelli
May 28, 2007 07:38 AM
2K Teggy
Dec 6, 2003 03:41 PM
vtecman
13
May 13, 2003 12:41 AM
