GSR JRSC install help
Old Jun 20, 2005 | 05:12 PM
boostedeghatch's Avatar
Default GSR JRSC install help
i'm in the process of installing a JRSC on a 94 gsr motor.
there is a water line under the TB that goes to the intake manifold on my skunk2 IM.
in the JRSC manifold, there is no place for this water line thats coming from under the TB.
anybody know where to i put this line?
i was thinking of T'ing off the water line that goes to the IACV sensor on back of the TB, but don't know if that will work.
any ideas?
Old Jun 20, 2005 | 08:24 PM
Default Re: GSR JRSC install help (boostedeghatch)
can i tee of the water line that goes from the front of the TB to the thermostat housing?
i don't want to tap the JRSC manifold for this water line....
Old Jun 20, 2005 | 09:54 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeghatch &raquo;</TD></TR><TR><TD CLASS="quote">
in the JRSC manifold, there is no place for this water line thats coming from under the TB.</TD></TR></TABLE>
Are you positive? That doesn't sound right. There should be two water ports on the manifold. They should be right next to each other, one faces the firewall, the one for the TB faces up. That's on my SOHC kit at least...
Letter "K" goes to my throttle body
https://honda-tech.com/zerothread?id=1283655
Old Jun 20, 2005 | 10:19 PM
Default Re: GSR JRSC install help (EnzoSpeed)
i think i found it...
here's my manifold i just got:
i'm thinking the bolt that is there on the left side is where i need to put a fitting for the water line that goes to the right side of the TB.
what you think?
Old Jun 20, 2005 | 10:23 PM
EnzoSpeed's Avatar
Yup, that's it. The manifold must be already set up for a TB heater bypass.
Old Jun 20, 2005 | 10:49 PM
do you know what size that fitting is?
i will need to go get one tomorrow.
edit: never mind.. on the jr website it says 1/8 npt x 5/16
boostedeghatch
Jun 20, 2005 09:09 PM
BringIT
Dec 1, 2003 11:35 AM
WS6Dreams
Aug 23, 2003 04:57 PM
