JRSC poor mans R help!!!!
Old Sep 20, 2010 | 01:39 PM
tstchatch's Avatar
Default JRSC poor mans R help!!!!
b16 sir head,
b18c1 bottom end,
both are stock with stock head gasket,
70mm str throttle body
10 lb enydn stepper pulley
450cc dsms
thats the setup
im running a gsr turbo chip and i pulled the .bin file from xencron.com but i cant get the car to idle properly and everytime i try to rev it pased 2k rpm, it bogs out. plugs and wires are good, but i feel like its getting too much fuel and not enough air. could the new, larger throttle body affect it that much?
thanks HT
Old Sep 20, 2010 | 05:51 PM
fv8s's Avatar
Default Re: JRSC poor mans R help!!!!
it would not effect it to the point where its not going to idle. not to be an a-hole but do you know how to use the program? im not a tuner by any means but maybe if you posted your file an actual tuner can help you out. (this may get moved to engine managment/ tuning)
Old Sep 20, 2010 | 07:33 PM
Spawne32's Avatar
put a wideband in that thing before you blow it the hell up
Old Sep 20, 2010 | 08:08 PM
cibao2ner's Avatar
phearable or xenocron should be able to make you a custom chip..there more to it than just changing how many cc's on the injectors...unless it for 450cc dsm it not gonna idle..
Old Sep 20, 2010 | 09:29 PM
tstchatch's Avatar
the .bin file i downloaded is from xenocron and was for the 450cc injectors... no bro your not being an A-hole. wide band is in the mail on its way... i was thinking timing but everything is matched up (unless the changing from b18 to b16 heads needs some minor ajustment or advancement that im unaware of)
CrazyFNG
Feb 16, 2012 02:32 PM
MOVE OVER
Jul 31, 2009 03:34 PM
mike3
Sep 9, 2007 05:44 AM
JohnnieChimpo
Jul 15, 2007 02:03 PM
Ls5000
Dec 16, 2005 12:20 PM
