JR Map Sensor Controller for JRSC
Old May 29, 2008 | 11:54 AM
c_trick's Avatar
Default JR Map Sensor Controller for JRSC
Hi guys.
Could anybody help me?
So, i have a Honda Del Sol SI 1997 SOHC and i bought a JRSC with RC 440 fuel injectors, Hondata S300, Walbro fuel pump, Innovate wideband...
And yesterday, i received an used Jackson Racing Map Sensor Controler.
The problem is that the JR map sensor controler is in great condition but i don't have the map sensor spacer.
The map sensor spacer is located between the OEM map sensor and the throttle body.
Is it possible to have a lot of pics of this map sensor spacer?
Old May 29, 2008 | 07:13 PM
HiProfile's Avatar
Default Re: JR Map Sensor Controller for JRSC (c_trick)
If you have S300, there's no reason for the JR Map controller, let alone the spacer, aka missing link. That unit is when you use a stock ECU that throws a CEL if it senses any boost. The S300 needs to sense boost to work properly. So use one or the other, not both.
Old May 30, 2008 | 12:41 AM
c_trick's Avatar
Default Re: JR Map Sensor Controller for JRSC (HiProfile)
Thanks man.
But is it possible to use the OEM map sensor with the S300 without problem?
Or is more interesting to change the OEM map sensor by another one? And which one?
And what do you think about it?
http://cgi.ebay.com/ebaymotors...&rd=1
Old Aug 31, 2009 | 04:26 PM
jaybyrd's Avatar
Omni Power makes a 1-4 bar map sensor. I am curious if anyone has used it and their results.
Old Aug 31, 2009 | 07:50 PM
Jaker's Avatar
Using the OEM Honda Map sensor, and the Hondata S300, it is possible to run up to about 11psi of boost. However, you must change the plumbing of the MAP sensor, as the OEM location of the MAP sensor on the D16Z6 in your 1997 SOHC Si will not allow the ECU to read boost as it must to be able to fuel the engine correctly.
The boost is produced after the throttle body, and the OEM MAP sensor location is at the throttle body.
Old May 29, 2010 | 07:05 PM
smurfin's Avatar
i need a jackson racing map controller and pulley assembly..thanks..
for a 1992 civic sohc d16
Old May 29, 2010 | 07:06 PM
smurfin's Avatar
also need pics and any info on the install
reddysol
Sep 8, 2007 10:57 AM
methos713
Jun 11, 2007 12:43 PM
Civicman86
Sep 21, 2006 08:25 PM
LSVtechnologytur...
Dec 9, 2004 04:26 AM
