JRSC on integra gsr question. did search
hi guys. i am considering getting a JRSC for my daily driven gsr after what happened to my retarded turbo install last week.
anyways, i had a few questions.
1-what is a good price for a new kit for a 2000 integra gsr (i searched but archives are down)
2-when using a hondata with the jrsc, will the kit still remain smog legal?
3-when using hondata s200 with boost, do i need to buy anything else besides a chipped p28 and a obd2-obd1 convertor to make it work on my 2000 gsr? (since i already have these item)
-also, do i still need to upgrade my stock injectors to maybe dsm 450's or is stock injectors just fine?
4-do people usually change their spark plugs to one degree colder just like for turbo?
any answers will help me out a lot. i have done countless hrs of research on turbo and am pretty clueless on supercharhers. i had a TRD SC on my 98 camry so im familiar with the eaton roots style SC, but i dont know much about it regarding the gsr. thanks guys
and again, i tried searching but the search function is giving very limited info. thanks
What is this crap?
Re: JRSC on integra gsr question. did search (Tru Dynamix)
1) 2450
2) probably
3) umm.. ait sensor? upgrade injectors... 450s would suffice. 310s might be fine too
4) yes ngk #6097 is 2 steps colder or try bosch 4227 i used these on my SC setup and they worked fine
intercooled turbo is night and day difference over sc as far as power, and i dont know what lag is.
2) probably
1)i paid 2300
2)don't know-i don't use it
3)i use stock injectors and am fiddling around with a p73 Type R ECU, so far so good!
4)u need a colder plug, the stock GSR is heat level 6...use a 7! You can use NGK BKR7E(copper) or BKR7E-VX(platinum)
A higher flow fuel pump is necessary!
[Modified by JChcmax, 7:35 PM 4/3/2003]
Re: JRSC on integra gsr question. did search (JChcmax)
as for now, i have a walbro 255hp fuel pump in my car left over from my turbo install. that should do. i also have ngk-bkr7e in (i think thats the model) but its one step colder for sure.
on a side note, is it safe to run one step colder spark plugs on a totally stock car? or should i just spend the extra 10 minutes swapping them out?
if i can get a full kit for $2350 or so shipped, i need a few months of being stock.
and this question is totally asking for FLAMING but what are some expected 1/4 mile times with the jrsc kit with regular boost settings and decent driver? (with hondata )
[Modified by Tru Dynamix, 5:24 AM 4/4/2003]
I think I have the Walbro"GS242" fuel pump. Those NGKs are good. The cold plug shud be ok in the stock engine. About the 1/4 mile? I personally have yet to do it. I will soon! I've read about low 14's or high 13's????
low 14's or high 13's is good enough for me.
also, do i need to upgrade my stock fpr? i have my hondata s200b still so i think it might be possible to have the tuner do it where it can use my stock fpr. he wrote me a good basemap for my turbo using the stock fpr so im hoping it would go for the jrsc too.
where can i find this kit for a good price? everywhere online i checked so far sells them for $2600+
if you're using hondata, then your stock FPR will be fine. the JR kit comes with an FMU, but i think you know by now to throw it in the garbage, along with the JR relay hack.
i just ordered my type R kit for $2600 shipped from http://www.velocityresources.com. keep in mind the type R kit costs more than the gsr. give them a call and see what they can give you for a price, unless someone else replies to this thread with a lower one. they give really good service though
[Modified by keebler65, 11:41 PM 4/3/2003]
Re: JRSC on integra gsr question. did search (keebler65)
thanks for the answers.
but i just realized after doing a bunch of research on the jrsc, that i need to slow down and get some basic info down..
i am very new to this kit so please bare with me.
1- ok, so when u get this kit brand new with no upgrades, how many lbs of boost does the gsr see? and roughly how much whp does this equal to?
2- also, when using a hondata s200b, will the boost level stay the same or will i be able to boost a few lbs more? if so, how many lbs is considered "moderate/low"?
if anyone has time, IM me with your aim and we can talk. its better than taking up bandwidth and probably irritating some people on this board
