JRSC installed.. now small problem
Old Oct 9, 2003 | 11:03 PM
  #26
KingDsi's Avatar
Default Re: JRSC installed.. now small problem (madeiniraq)
If you have the JR "fuel enrichment circuit" installed, remove it. That is your problem. At least that is my belief...
Old Oct 10, 2003 | 08:00 AM
  #27
exciv2000's Avatar
Default Re: JRSC installed.. now small problem (KingDsi)
yeah, it might be the fuel enrichment relay. The only way to really tell and get it working right is to get it tuned on the dyno with a wideband. I can't stress this enough.
Old Oct 10, 2003 | 08:36 PM
  #28
MADEINIRAQ's Avatar
Default Re: JRSC installed.. now small problem (exciv2000)
update...
not runnin the fuel enrichment relay..
bought magnacor wires and put in new bkr7e plugs gapped to .30
old plugs the electrode was kinda mushroomed.. just slightly and they were really black .. and the ground strap was whiteish.
the car still hesitates under boost after driving it hard.
Old Oct 10, 2003 | 08:49 PM
  #29
greekspeed's Avatar
im assuiming u are not running an fmu correct? cuz if u are then that would be the cause of ur super richness... i had the same problem in my car... i leand it out a bit and it made a world of difference
Old Oct 10, 2003 | 08:52 PM
  #30
greekspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madeiniraq &raquo;</TD></TR><TR><TD CLASS="quote">
hmmm it may not be a fuel problem at all.... it could be a slight bit of belt slippage when suddenly acellerating, and then the belt "catches" up so to speak.
Old Oct 10, 2003 | 08:58 PM
  #31
MADEINIRAQ's Avatar
Default Re: JRSC installed.. now small problem (greekspeed)
i'm running afc hack..
settings are -40% at idle
-36 from there up. -35 throws map code.
i'm running 9psi
i was thinkin belt slippage but i tightened them more.. and i still read 9psi while it does this
Old Oct 11, 2003 | 07:46 PM
  #32
MADEINIRAQ's Avatar
ok.. using voltmeter while i am at WOT the voltage was almost 1.. 9.7-9.8 ish.. and then it started bogging and goin to about 8.9..
maybe i need a fuel pump? you think the pump gets hot after all that demand and finally it kinda gives up..
i would't think so.. because it would drop lower. also replaced cap and rotor today.. didn't help.
anybody?
maybe i'm running too much timing retard with -1degree/lb boost and stock timing
Old Oct 11, 2003 | 08:07 PM
  #33
exciv2000's Avatar
Are you runnig the stock fuel pump? Yes, the fuel pumps can heat up and reduce the efficiency of their flow. Stock pumps don't flow much at high fuel pressures. If you haven't upgraded your fuel pump to a Walbro 190 or 255, I'd recommend that.
Old Oct 11, 2003 | 08:18 PM
  #34
KingDsi's Avatar
Oh, ok. I'm sorry. You should roll back your base timing a little and have no more than .5 degree per lb retard. Is the retard **** easily accessable during driving? If so, drive into boost with it set at 1*, slowly turn it back til you feel more power. But again, keep it in boost. If you feel leary about driving fast and boosting while playing with *****, get a friend to do it...
Old Oct 11, 2003 | 08:26 PM
  #35
MADEINIRAQ's Avatar
i'm using a boost retard chip from pgmfi from j davis
my only way of adjusting is advancing say 2 degrees to total 7 degrees retard at 9psi and so on.
is everybody usin walbro intank pumps.. any alternatives?
Old Oct 11, 2003 | 10:40 PM
  #36
exciv2000's Avatar
Which is it, JR BTC or boost retard chip or both?
Old Oct 12, 2003 | 08:47 AM
  #37
MADEINIRAQ's Avatar
just boost retard chit.. never said anything about btc.
Old Oct 12, 2003 | 11:10 AM
  #38
exciv2000's Avatar
My bad, I read JR BTC somewhere, must have been in another post, possibly not even this board. Sorry 'bout that.
Old Oct 12, 2003 | 11:52 AM
  #39
sharkcohen's Avatar
Maybe you should get the car professionally tuned on a dyno....
Old Oct 12, 2003 | 01:08 PM
  #40
1strdko's Avatar
Default Re: JRSC installed.. now small problem (sharkcohen)
My guess is its the chip.
Old Oct 13, 2003 | 02:37 PM
  #41
2001teggsr's Avatar
Default Re: JRSC installed.. now small problem UPDATE.. please help. (madeiniraq)
It sounds like its too rich most people can run 9 pound pulleys on stock injectors
Old Oct 13, 2003 | 03:51 PM
  #42
SDT Project EF's Avatar
i had bogging check grounds, check spark plugs
Old Oct 15, 2003 | 09:33 AM
  #43
joshwhe's Avatar
when the bogging would start it would fall to around 8.0V would fall from 9.7V to around 8.0V which would mean that its loosing fuel pressure or somehting along those lines. leading to the fuel pump as the problem..... we will find out this weekend
i have a walbro 255 in my rx7 and i dont trust it at all... i know alot of honda guys use it and it works fine ....... but ive heard bad things about them..... a 255 walbro is a big upgrade from a stock honda where as its not so much for me so ill be upgrading again as soon as funds let me.
Old Oct 15, 2003 | 10:47 AM
  #44
civictypenos's Avatar
what exhaust are you using,restrictive??
Old Oct 17, 2003 | 11:22 AM
  #45
joshwhe's Avatar
Default Re: JRSC installed.. now small problem (civictypenos)
he has stock air box exhaust mani and piping
test pipe to a straight through muffler
Old Oct 17, 2003 | 11:23 AM
  #46
joshwhe's Avatar
Default Re: JRSC installed.. now small problem (joshwhe)
its not a problem of flow tho ... if it was it would do it all the time or when ever he built boost ... where as the problem only happens after he gets on it for a while.
Old Oct 17, 2003 | 08:53 PM
  #47
MADEINIRAQ's Avatar
put in an rx7 130 lph pump tonight.. still does it.. not sure if it does it less but still does it.
Old Oct 17, 2003 | 09:29 PM
  #48
JDMEG-6's Avatar
Default Re: (madeiniraq)
Check the heat range on the plugs they are either too hot or too cold of plug. You shouldn't run stock plugs on boost. It could also be a fuel problem. I had a situation once where I installed a walboro fuel pump that made so much pressure it was pushing gas right past the pressure regulator man did it bogg. I pulled the pump replaced it with a gsr pump end of problem think you are running way rich. Check your plugs if they are black way too rich if they are white too lean of they have a nice color of brownish grey perfect. Really important to tune the car use a wide band o2 sensor.
Old Oct 17, 2003 | 09:35 PM
  #49
hondahvn's Avatar
if fuel preasure is a concern put a guage on the car and see if it drops... i seriously doubt this is the problem tho. these fuel pumps pump enough preasure to run that set up at 8 psi with an 8 to 1 fmu that would be a 64 lb increase you are asking it to run half of that or even less
Old Oct 17, 2003 | 09:39 PM
  #50
hondahvn's Avatar
Default Re: (hondahvn)
when its cold does it run fine and when its hot run bad or does it run badd all the time and just run worse when its hot? did you do any other mods at the same time? does it build full boost fast like a sc should or slow? if you stay on it long enough does it ever clean up and pull or does it get deader.
