JRSC installed.. now small problem
Old Oct 8, 2003 | 04:20 PM
MADEINIRAQ's Avatar
Default JRSC installed.. now small problem UPDATE.. please help.
installed my jrsc in my 89 civic si with b16 friday.
using vafc hack.
pr3 boost timing retard chip
dsm 450's
bkr7e ngk plugs
motorvations stepper pulley. gettin 9lbs of boost
The Problem
when the engine warms up real good.. and i hit boost in 3rd gear the engine boggs.. my a/f guage still reads rich. and the vafc still reads boost which leads me to believe my plugs are shot? I'm using cheap d series plug wires.. which i'm sure isn't helping.
as the engine gets hotter and i drive it more. it starts to do it when i hit boost in any gear. runs fine in vacuum but when boost hits it boggs.
no check engine light.
any ideas?
Modified by madeiniraq at 12:35 AM 10/11/2003
Modified by madeiniraq at 12:37 AM 10/11/2003
Old Oct 8, 2003 | 04:26 PM
sharkcohen's Avatar
Default Re: JRSC installed.. now small problem (madeiniraq)
I would make the assumption that you are running too rich. Have you had it tuned???
Old Oct 8, 2003 | 04:34 PM
GaRn's Avatar
your plugs are gapped to large!!! gap them to .34 or so... even lower if you have to.. be sure to get a couple steps colder plug to.. man your car is gonna be SOOO Fast..
Old Oct 8, 2003 | 04:52 PM
Mr. Softee's Avatar
Default Re: (GaRn)
pink
Old Oct 8, 2003 | 06:24 PM
MADEINIRAQ's Avatar
Default Re: (94goldjungsr)
they are gapped .30 not tuned yet.. probably tuned with wideband next week
afc settings are -40 1k and -36 for everything after that.
most likely too rich.. it kinda runs like it did when i had cams and a mugen chip.. would start up and bogg.. had to kinda gas it in the cold mornings.
Old Oct 8, 2003 | 06:25 PM
MADEINIRAQ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">pink </TD></TR></TABLE>
yes.. i'm a girl.. i like pink
Old Oct 8, 2003 | 06:37 PM
Ricey McRicerton's Avatar
Default Re: (madeiniraq)
Hell I tried to do my whole valvecover hot pink...couldnt find any engine paint...Im having the same problems..check your MAP sensor..that's what was messing me up!!
Old Oct 8, 2003 | 06:53 PM
MADEINIRAQ's Avatar
Default Re: (Ricey McRicerton)
was your map throwing a code?
gonna put new plugs and maybe wires tomorrow. if that solves it.. then i'm off to tune asap.
Old Oct 8, 2003 | 07:10 PM
15psi of fun's Avatar
what is a pr3 boost timing retard chip where did you get it and dose it work
Old Oct 8, 2003 | 07:14 PM
MADEINIRAQ's Avatar
Default Re: JRSC installed.. now small problem (EFrollingout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFrollingout &raquo;</TD></TR><TR><TD CLASS="quote">what is a pr3 boost timing retard chip where did you get it and dose it work</TD></TR></TABLE>
got the .bin file off pgmfi forum. had it burned at a local shop. i hope it works. well the chip works. the car runs. vtec engages where i put it. and i'm running stock timing and no detonation
Old Oct 8, 2003 | 07:16 PM
Mr. Softee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madeiniraq &raquo;</TD></TR><TR><TD CLASS="quote">
yes.. i'm a girl.. i like pink</TD></TR></TABLE>
Old Oct 8, 2003 | 07:41 PM
Nope..the only code i had gotten was running rich...thought it was my 02..now that I have better diagnostics stuff I checked and my MAP is all whacked out. Telling me im at 6.8 in/hg at idle..wrongo..my boost guage says 20!!
Old Oct 8, 2003 | 07:44 PM
keebler65's Avatar
here come the leg humpers
Old Oct 8, 2003 | 07:46 PM
Default Re: (keebler65)
Hahah great pic man!! Seriously saying your a girl on this site will get you the world...next time nobdoy want to answer my questions Im just going to say ...hey Im a girl..somebody help me and Ill post a pic (sorry off on tangent...and no offense to the origninal poster, just noticing a trent here)
Old Oct 8, 2003 | 07:55 PM
MADEINIRAQ's Avatar
haha.. i'm not a girl.. i was just waiting for the leghumpers.. do you think i would have over 1,000 post and not know what saying i'm a girl would do..
you damn leg humpers.. just answer the question haha
Old Oct 8, 2003 | 07:58 PM
joshwhe's Avatar
so your not a girl?
Old Oct 8, 2003 | 08:02 PM
Muckman's Avatar
Moderator in Chief
I think its your pink spark plug cover thats causing you to bog. If you switch to a carbon fiber one that will give you 5-10hp.
But seriously, try leaning it out a little bit and see if it improves. Big question is: is you AFR gauge hooked up to a wideband?
Old Oct 8, 2003 | 08:05 PM
MADEINIRAQ's Avatar
Default Re: (Muckman)
not hooked to wideband.. which is why i don't wanna lean it out.. but do you think it is because of running rich.
i will tune with wideband asap. but for now.. plugs are cheaper than a motor.
Old Oct 8, 2003 | 08:09 PM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madeiniraq &raquo;</TD></TR><TR><TD CLASS="quote">gonna put new plugs and maybe wires tomorrow. if that solves it.. then i'm off to tune asap. </TD></TR></TABLE>
I doubt it will help, you most likely have a (lack of) tuning issue.
Old Oct 8, 2003 | 08:20 PM
90civichbsi's Avatar
Default Re: (sharkcohen)
kinda OT, but ive always wondered how well the pulleys fit on a 4th gen, upper pulley and the crank pulley, did it require any extra denting? i hardly have any clearance as it is.
Old Oct 8, 2003 | 08:31 PM
keebler65's Avatar
Default Re: (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">kinda OT, but ive always wondered how well the pulleys fit on a 4th gen, upper pulley and the crank pulley, did it require any extra denting? i hardly have any clearance as it is.</TD></TR></TABLE>
the pulley sticks out the same distance as your stock b series alt pulley would. the pulley is twice as thick, but the alternator is pushed back to make up for this. check my sig for details...
Old Oct 8, 2003 | 10:00 PM
1strdko's Avatar
Maybe its your DSM they some times give you a jerk or two due to their injector characteristics.
Old Oct 9, 2003 | 07:11 PM
MADEINIRAQ's Avatar
Default Re: (1strdko)
bump.
i think my plugs/ cap / rotor may be bad.. now that i think of it the cap and rotor are over a year old and the wires are el cheapo crap.
anybody agree?
Old Oct 9, 2003 | 07:45 PM
keebler65's Avatar
well a year old for a cap and rotor isnt bad at all unless you drive 50,000 miles a year. the wires may be hindering you, but i'm sure it wouldnt cause the bogging that you're describing. but i would recommend getting some new plugs with the correct heat range and gap them to the right spec just to eliminate this as a possibilty.
Old Oct 9, 2003 | 09:26 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
WHY hi2u!!..... butsekz lolol!
