JRSC HELP!!!!
Old Aug 29, 2009 | 12:02 PM
spliftacus's Avatar
Default JRSC HELP!!!!
Hey guys, I have recently supercharged my d16z6 with a JRSC. The kit is on the car and it runs fine for about 10 seconds the cuts off. I have been trying to figure out why this is, and may have come to the conclusion that it might be a part that was missing from the kit. I think it is some sort of boost solinoid or sensor of some sort. The guy that I bought it from said nothing about it and that it was a complete kit. Does anyone know where I can find this part, or if there is a way to run my setup without it?!? Please help, kinda need my car to go to work. Thank you!
Old Aug 29, 2009 | 12:57 PM
spliftacus's Avatar
Default Re: JRSC HELP!!!!
Sorry didn't mean to make 2 threads. But please help!
Old Aug 29, 2009 | 01:02 PM
nonpoint986's Avatar
Call Jackson racing and see if you can buy it indivigually.
Old Aug 29, 2009 | 03:07 PM
spliftacus's Avatar
ok so i just found out that it is a fuel enrichment relay... do i need it?
Old Aug 29, 2009 | 03:12 PM
joppe's Avatar
Get your ecu chipped and tuned.
Old Aug 29, 2009 | 03:17 PM
spliftacus's Avatar
it is base mapped
Old Aug 30, 2009 | 02:21 PM
daveb91's Avatar
Then you dont need the JR fuel crap. Is the base map for boost??? Is your map seeing boost?? What inj are you running?
Old Aug 31, 2009 | 03:59 AM
spliftacus's Avatar
yes the base map is for boost and i am running 450's
Old Sep 1, 2009 | 07:31 AM
joppe's Avatar
get it tuned and new chip, then its right way and ur engine will last and make power. Basemap cannot run right.
Old Sep 1, 2009 | 10:35 AM
Jaker's Avatar
It is possible that your basemap chip is not configured for boost. You ECU is seeing boost, and the chip is not telling to ECU to expect it, so the ECU thinks there is a problem and shutting down the engine. Are you getting any CEL codes (Is the check engine light coming on?)?
csmsi311
Nov 28, 2003 03:02 PM
Pfieff
Jun 13, 2003 12:03 PM
GreddySi99
Mar 17, 2003 03:15 PM
