JRSC fitment for a JDM Sol SiR (B16)
I have a JDM B16a2 Del Sol and am looking to buy a JRSC. I have searched previous posts but not much info is available for my application. I have been told that the 99-00 Civic will fit my application with some slight modifications.
I am on quite a tight budget but am also looking at doing things right. Ideally, i would like to just bolt on the SC and go. Later on, i want to be in a position where if i want to increase boost, then i can. I have a lot of questions that are just nagging me so please bear with me:
1) How easy is it to modify the fitment of the 99-00 Civic JRSC to fit the SiR??
2) Can i literally just bolt the JRSC and go (ok, i know you have to retard timing and adjust the fuel pressure and probably reset the stock ecu)?
3) I already have a (unfitted) Hondata S100 unit - would it be beneficial for me to upgrade to the S200 unit with boost option?
4) If i upgrade, do i need to install bigger fuel injectors (440cc)??
5) What else do you recommend? Remember i am on a tight budget. On the JRSC webiste, the recommend fitting a high performance fuel pump. Would it also be worthwhile going for the Hondata IM gasket too? Anything else?
6) Should i revise the gear ratio's?
7) Are the Stage 1 and 2 upgrades worth the money?
Thanks!
Modified by caranjo at 7:15 PM 4/10/2005
Thanks!
Re: JRSC fitment for a JDM Sol SiR (caranjo)
i ran jrsc on stock b16a with stock inj and fuel pump no problem. 6 psi. as for the kit, you have to make a ring to go on the alternator pulley shaft and then put the jrsc alt pulley on over that kinda like a shim cause the kits are for obd2 alternator and they have a bigger shaft. i used a small hose clamp put it around the shaft and them rubber malleted the double alt pulley on to it. WORKED PERFECT!!!
