jrsc b16
Old May 16, 2008 | 12:57 PM
kyle-Lst's Avatar
Default jrsc b16
first of all heres my setup
b16a (stock block)
supertech valvetrain with flat face valves
skunk 2 stage 2 cams
hi tech rep header full 2.5 in exhause
jrsc race kit
ctr crank pully
hondata s300
im working on getting all this running i just need help on the base map. i dont know that i have time to get it tuned properly since i ship out in 11 days. im just trying to get it to where it is drivable and half way safe if someone can help me i would really appriciate it. im from IN, so if someone knows somewhere i could get it tuned in my time frame would be nice to..
thanks for any help
Old May 19, 2008 | 11:09 AM
kyle-Lst's Avatar
Default Re: jrsc b16 (kyle-Lst)
nothing? i just need to know somewhere to get it tuned somewhere close to indy
Old May 19, 2008 | 11:49 AM
crazybri's Avatar
no mention of injectors?? In hondata smanager there is are calibrations for a supercharged b16 with 440's and also 550's..... So if you had any of them injectors. you could use 1 of them maps to get you to a tuner.
Old May 19, 2008 | 08:07 PM
C_Rock77's Avatar
Default Re: jrsc b16 (crazybri)
Based on everything I've READ...reading posts by guys like Veris, JDogg, etc...those cams will have too much overlap.
You might want to step down to something like a Stage 1 if you have them available.
You can start w/ the B16Supercharged basemap that corresponds w/ your injectors to get it to a tuner.
The one I used for my GSR was pretty close. It's rich as Hell up top....but it'll get you to the tuner. Just don't boost it hard.
Old May 20, 2008 | 04:43 AM
kyle-Lst's Avatar
Default Re: jrsc b16 (C_Rock77)
i have rc 440s and im on a time crunch i leave next week i dont have time to get other cams.. are you just saying these will run like **** in low rmp? i wanted to pick a somewhat big cam to help with top end since the supercharger falls off
Old May 20, 2008 | 12:38 PM
HiProfile's Avatar
Dont' boost AT ALL with a basemap if you have huge cams installed. If you ship out in a week (military/etc deployment, not taking car with), I'd suggest this: use the money you'll spend on new pistons/valves/block machining when you blow it up and spend it on an Evo/STi/Z06 rental. Then when you get back, trailer it to a tuner or contact one to get a decent basemap - don't rush into it.
Rushing+guesswork(basemap^2)=disaster.
Old May 21, 2008 | 07:00 AM
kyle-Lst's Avatar
Default Re: jrsc b16 (HiProfile)
thanks im not planning on driving it until i get it tuned or at least not hard so hopefully i can find someone to tune it soon
civicsi0721
Sep 9, 2009 12:34 PM
kidrolla
Nov 8, 2007 10:31 AM
slammed00si
Mar 8, 2004 06:38 PM
REX VT
Oct 26, 2003 06:16 AM
