Who can hook me up with a PW0 .bin file optimized for B16 JRSC?
Re: Who can hook me up with a PW0 .bin file optimized for B16 JRSC? (REX VT)
Com'on people now.. somebody must use an optimized fuel map without the help of a piggy-back or stand-alone.. I offer money
I highly reccomend the services of hardlowrdranger, from this board. or j davis , also from this board.
-PHiZ
-PHiZ
If you are offering money, why not get a solution specifically designed for yor application?
One of your solutions is a Hondata Stage 2 system. We spent several weeks optimising a JRSC with a B16A and 440 injectors. Hondata dealers have access this to this information. The value of the tuning alone (20 hours) far exceeds the value of the Hondata system.
What fuel pressure and injectors do you run?
There mught be one problem - the Euro CRX ECU does not use a knock sensor board and is incompatible with the Japanese PWO ECU files. Most people in your situation convert to an OBD I ECU.
For a reference you might like to contact Oscar Jackson himself, as this is what he uses on his B16A CRX.
