jrsc 200+ integra
Old Mar 13, 2003 | 05:53 PM
redteg's Avatar
Default jrsc 200+ integra
i want to get 200 if not more on my 1998 integra ls. iwaswondering whatineed to runtoachieve this. i know the max you can run on the ls blower is 10 psi so i need to know what bolt onsi need to get 200+
Old Mar 13, 2003 | 05:58 PM
yellowhonda88's Avatar
Default Re: jrsc 200+ integra (redteg)
with that motor it would be relativly easy. At most you would need i/h/e, 8.5-10 psi and hondata. It is not hard to make a B16 get 220 at 8.5 psi with hondata.
Just go turbo and do it with 6psi and with all the neat noises to boot
Brett
Old Mar 13, 2003 | 06:09 PM
keebler65's Avatar
Default Re: jrsc 200+ integra (yellowhonda88)
the JRSC kit for the LS is not very effective to tell you the truth. we were just discussing this the other day in this forum. do a search or look a few pages back to see the details about the LS kit.
Old Mar 13, 2003 | 06:16 PM
redteg's Avatar
Default Re: jrsc 200+ integra (keebler65)
yeah i know but i want to go supercharger so im gonna do it anyway i just want to make 200 if not more and i will be happy it s a dailydriver i want tokeep it clean simple and fast
Old Mar 13, 2003 | 06:28 PM
romeo619romeo's Avatar
cant drive the supercharger with the AC on feels like ****
Old Mar 13, 2003 | 06:43 PM
illi Adik's Avatar
Ditto, check it out, it was rather extensive.
Old Mar 13, 2003 | 07:19 PM
CRVRX's Avatar
Default Re: jrsc 200+ integra (Jackson4Door)
The main problems with the LS kit it uses a M45 blower ( Same as SOHC kit) , I have made 195 WHP at 10 PSI which is running the crap out of the blower.
Look on Endyns site, He shows you how to use the M62 blower on the LS manifold which will give you more potential.
http://www.theoldone.com
Old Mar 13, 2003 | 09:54 PM
enginetiks's Avatar
Default Re: jrsc 200+ integra (CRVRX)
I'ts not that hard to make 200 hp with an ls blower
I made 227 hp and187tq with an m45. B20 crank pulley, endyn stepper pulley, kamikaze header, 440cc injectors, hondata, crane forced induction cams, jg throttle body. We ran the car for a year without a problem
Old Mar 14, 2003 | 01:10 AM
mskibbz-T's Avatar
I believe GreekSpeed on here is running the modded M62 on his LS
Old Mar 14, 2003 | 03:06 AM
96IntegraRS's Avatar
Default Re: jrsc 200+ integra (mskibbz-T)
LSAvenger had an M62 on his B18B and it was spun at 10psi, I estimate it made 190-195 HP. According to him, it wasn't necessarily worth the trouble.
I think the consenus is that with a STOCK BLOCK, the M45 @ 9-10PSI maxes out around 200HP. Injectors, fuel management, and internals wil increase this (about 20HP from what I have seen here).
You are crossing a threshold from M45/Stock Block to M62/internals, et cetera... the $$$ is the main difference.
I think the point of this thread is that the more $ you invest, the faster you go. If you want a Ferrari, buy a Ferrari. If you want a quick reliable Honda, go the SC/small blower route. I personally have gone this way and am satisified, but one you have it you always want more power
Old Mar 15, 2003 | 01:52 PM
redteg's Avatar
Default Re: jrsc 200+ integra (mschvs)
you made 227 horse and 187 torque on an ls motor and had no heating problems and i ran fine. is this agood setup for daily driving
Old Mar 15, 2003 | 09:31 PM
enginetiks's Avatar
the car was fine for everyday driving...but those numbers were created after 4 hours of dyno time and the program that resulted was very agressive. oh yeah...that was 100 octane numbers..92 octane got us 209hp which is still pretty good. The main difference was the cams, we bumped up @20 hp after the cams were installed. Check crane cams for their supercharged/nitrous grind for the ls
bhigh
Oct 30, 2010 10:11 AM
Weapon_R
Sep 5, 2004 01:28 PM
abs0lutexer0
Oct 28, 2003 01:55 PM
redteg
Mar 12, 2003 04:35 AM
