402T cam questions
402T cam questions
ok so i know the 402t cams are for turbo applications on the b18 non-vtec, but say i put the cams and valve train on and i dont put my turbo system on yet, will i have more power over stock or less with just the 402T cam ? cause i dont want to be cruising around with less power than i have stock. nawmean. but yeah advice welcome.
Re: (99whitejizzer)
its hard to say, a turbo cam has almost no overlap which a NA motor needs to help create a vacume in the cylinder. Im not sure about lift and duration on a turbo cam since on a turbo motor the air is just waiting for the valve to open instead of it having to be pulled in by vacume on the piston it is just shoved in
