JB weld with heat?
Old Apr 20, 2008 | 08:44 PM
HamiltonRex's Avatar
Default JB weld with heat?
Hey.. my friend got a head from a junkyard, for his 92 civic. When we were bolting up the exhaust manifold one of the studs pulled out of the head. Now, he wants to know if he can just mix up some JB weld put it on the stud and fire it in the hole, let it dry and tighten it up.
Sure it will hold, but how is it when it comes to temperature, will it break down? Hes just looking for a easy fix that will work.
I told him to drill/tap but.. he dosen't want to. So will the JB weld work?
Thanks!!
Old Apr 20, 2008 | 10:13 PM
welfarepc's Avatar
ive been told jb doesnt hold up well to heat.
i would use a timesert or helicoil if you cant afford the timesert kit
you can get a cheap knock off helicoil kit off ebay for about $25 that works great
Old Apr 21, 2008 | 02:59 AM
non-VTEC's Avatar
Default Re: JB weld with heat? (HamiltonRex)
JB can hold up to about 600deg according to the label on the instructions......the exhaust manifold and probably the studs get hotter than that.
helicoil the bitch.........
Old Apr 21, 2008 | 03:54 AM
turboteg2nv's Avatar
Default Re: JB weld with heat? (non-VTEC)
Do it right the first time. You'll have to helicoil it.
I used JB weld on my midpipe (which doesn't even get that hot) and it melted out within days.
Old Apr 21, 2008 | 06:59 AM
blackeg's Avatar
Default Re: JB weld with heat? (turboteg2nv)
i wouldnt jb that. either helicoil or drill and tap for a slightly larger size
Old Apr 21, 2008 | 07:29 AM
96 GSR-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg2nv &raquo;</TD></TR><TR><TD CLASS="quote">
I used JB weld on my midpipe (which doesn't even get that hot) and it melted out within days.</TD></TR></TABLE>
I used it in an app like that before and it didnt last either
Helicoil
Old Apr 21, 2008 | 09:00 AM
2point2's Avatar
Default Re: JB weld with heat? (96 GSR-T)
re-tap it with a bigger hole if you can get away with it..
Old Apr 21, 2008 | 01:07 PM
97grnrs's Avatar
Default Re: JB weld with heat? (2point2)
i did it b4 and it worked but dont overtighten it or it cracks.. and drill the hole a bit bigger so the stuff can have a solid form in there after its drilled and tapped
Old Apr 21, 2008 | 01:37 PM
Default Re: JB weld with heat? (97grnrs)
ok guys, we will drill it out and re-tap it next larger size.
thanks
invader_zim
Jan 24, 2013 09:19 PM
riceball777
Dec 25, 2007 07:19 AM
PlayDepot
May 25, 2005 09:36 AM
pub
Mar 21, 2003 02:51 PM
Brian_92GSR
Jan 16, 2002 03:06 AM
