J/R supercharger ?????
Old Jun 15, 2005 | 10:04 PM
94hybridcoupe's Avatar
Default J/R supercharger ?????
My buddy has a stock b16 J/R supercharged 6 PSI. he's getting a noise that sounds kinda like pre-ignition or fuel ping. only does it at full throttle, and goes away in Vtec. Timming is set at 16 and we have tried 18 and 14 degrees as well. If anybuddy has came across this problem, or has heard of it. chime in and help me out.
Old Jun 15, 2005 | 10:27 PM
EnzoSpeed's Avatar
Default Re: J/R supercharger ????? (94hybridcoupe)
So you're getting detonation, then you try both retarding and advancing your ignition? You doofs shouldn't be working on your own cars.
Old Jun 15, 2005 | 10:45 PM
I don't think it is detonating. it is more like a loud clicking sound. It isn't hesitating or anything. no loss in power, just an anoying noise.
How about you try answering the question next time jackass. that is why I posted it. just because you don't know the answer either, doesn't make us the "doofs".
Old Jun 15, 2005 | 10:50 PM
mtber's Avatar
Default Re: (94hybridcoupe)
Have your friend read: http://www.phearable.net/tech/....html
What is he using for fuel management ? An fmu ?
If so he should look into uberdata, crome, hondata, neptune etc.
SOHC_MShue's Avatar
Is the car tuned? What managment? Maybe try backing the timing down a few degrees and see if it goes away. If so then you know its probably pinging.
Old Jun 15, 2005 | 11:28 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hybridcoupe &raquo;</TD></TR><TR><TD CLASS="quote">I don't think it is detonating. it is more like a loud clicking sound. It isn't hesitating or anything. no loss in power, just an anoying noise.
How about you try answering the question next time jackass. that is why I posted it. just because you don't know the answer either, doesn't make us the "doofs".</TD></TR></TABLE>
You said it sounds like detonation and it only occurs at full throttle. That is detonation. JR superchargers don't ping. What more do you want? Back down your timing already.
Old Jun 16, 2005 | 11:02 AM
daredevil003's Avatar
well its not pinging, because if it was it wouldnt go away in vtec. but what you should really do is get it dyno turned.
Old Jun 16, 2005 | 11:03 AM
Default Re: (EnzoSpeed)
JRSC can ping, so dont say that they cant.
Old Jun 16, 2005 | 11:12 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (daredevil003)
any motor can ping if you **** up the tune enough
Old Jun 16, 2005 | 11:47 AM
i2un's Avatar
Hmmm...
Sounds like tip-in detonation. Detonating because the boost comes in quicker than the car's setup can transition for.
The base timing should be more like 10 degrees unless your friend has the JR map mod or some type of standalone.
Old Jun 16, 2005 | 06:11 PM
The car isn't tuned yet...he just is running what came with the supercharger as far as fuel management. Someone said to back the timing off like .8 degrees per/lbs of boost. Does that sound right.
Old Jun 16, 2005 | 08:05 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hybridcoupe &raquo;</TD></TR><TR><TD CLASS="quote">The car isn't tuned yet...he just is running what came with the supercharger as far as fuel management. Someone said to back the timing off like .8 degrees per/lbs of boost. Does that sound right. </TD></TR></TABLE>
See, there's your problem. It is tip-in. If I were you, I would buy a JR Map controller on ebay. They're only about $50 used, which is well worth it.
Without the MAP contoller, you have to overly retard timing just to get rid of tip-in. With the MAP controller, tip-in is virtually eliminated so you can run the actual timing you need with the supercharger.
It's kind of hard to ask us what timing to run. It depends on what octane you're using, what quality gas you're using, and your elevation. Just keep retarding the ignition until the noise stops.
Old Jun 18, 2005 | 06:12 PM
Cool, Thanks
Old Jun 18, 2005 | 10:21 PM
Qveon's Avatar
Pull your plugs, do ypu see black or shiny specs all over the white insulator? Does your electrode look damaged? If so you are detonating
bluedlude
Engine Management and Tuning
May 17, 2009 07:20 PM
jr408
Mar 19, 2008 09:18 AM
es_squared
Mar 15, 2007 06:48 PM
afrothunda713
Oct 17, 2004 01:37 PM
skierGT
Dec 12, 2003 01:04 PM
