I've got a problem...
Old May 15, 2010 | 02:30 AM
chris3385's Avatar
Default I've got a problem...
I took my car to get tuned last week, we ran the car a few times at 7psi, we ended up making around 280whp. So he was doing some fine tuning and we were going to turn the boost up and make another run but we made another pull at 7psi. You could see on the dyno graph, it dropped off at 6500. Vtec was kicking in then dying off. Then we noticed that the oil pressure wasn't quite right, when vtec would first kick in at 4500 oil pressure would be up around 50psi then go down to about 35psi at around 6000-6500rpms. I put a new oil pump on the car the first of last summer and just drove it with the GSR motor without the turbo. Car worked great.
If you have any idea what's going on let me know.
Thanks,
Chris
Old May 15, 2010 | 05:47 AM
fasthatch95's Avatar
Default Re: I've got a problem...
Turbo oil line not restricted enough will rob oil pressure from everything.
Old May 15, 2010 | 06:25 AM
sanman000719's Avatar
i was having this issue 2 weeks ago at the track man then went back to the dyno vetec was kicking then not kicking in so we tried to manually kick it at 5500rpm. Well long story short the screen on the vetec solenoid was clogged up so we cleaned it out and walla
Old May 15, 2010 | 09:37 AM
chris3385's Avatar
I am only running a -3an oil feed line, that shouldn't need a restrictor should it?
Old May 15, 2010 | 09:46 AM
intense4thgen's Avatar
what motor is this? you should have 50+PSI oil pressure at 3k rpm sounds like you have hurt it to me.
Old May 15, 2010 | 11:11 AM
my built block last year was making 15psi of oil pressure, and 450hp I didnt like that so we sent the crank out had it micropolished its now 20 under with nw bearings with no issues at all
Old May 15, 2010 | 12:18 PM
chris3385's Avatar
Its a JDM b18c1
Old May 15, 2010 | 01:45 PM
Mr.Spec's Avatar
clean our your vtec solenoid and screen
Slacker93eg
Aug 1, 2014 07:09 PM
90blackcrx
Nov 7, 2009 12:33 AM
ALL IMPORT
Jul 23, 2006 02:43 PM
DC2TEGGA-GSR
Jan 19, 2006 05:04 PM
Turbocivic94
Jun 11, 2003 03:38 AM
