ITR throttle body
Old Dec 27, 2002 | 10:25 PM
turb's Avatar
Default ITR throttle body
will an ITR throttle body fit the stock civic si intake manifold without modifications?
will having a bigger ITR throttle body improve performance on a turbocharged civic si?
Old Dec 28, 2002 | 07:32 AM
RAWB's Avatar
Default Re: ITR throttle body (turb)
All the ITR head is is a mildly p/p PR3 head-same as the B16A. So, yes it will bolt up-just make sure you get your Throttle body bored to match or it pretty much negates the mod. Also, the ITR mani will improve your top end, but you'll lose a little low-mid end torque.
Old Dec 29, 2002 | 05:42 PM
turb's Avatar
Default Re: ITR throttle body (integracon)
oh, i mean will the ITR throttle body bolt on to my stock b16 intake manifold.
i have a turbocharged Si so i want to swap my stcok b16 throttle body to a bigger ITR throttle body so i wanted to know if i need to modify my stock intake manifold to fit the bigger ITR T/B or will it just bolt on with no modifications. just the throttle body not the whole head or intake manifold.
sorry for the confusion.
thanks
Old Dec 29, 2002 | 06:23 PM
98civicEX's Avatar
yes, it'll bolt right in.
Old Dec 29, 2002 | 07:08 PM
RAWB's Avatar
Default Re: ITR throttle body (98civicEX)
The only thing to think about is, the ITR TB has a larger bore than the B16 IM. You probably won't get much gain, if any, and may even hamper your current performance.
Old Dec 29, 2002 | 07:13 PM
turbosol's Avatar
It will bolt up but you should port-match your intake manifold to the throttle body.
Old Dec 29, 2002 | 08:15 PM
SiRkid's Avatar
you are correct.
i knwo a few who have swapped out their si stuff for itr stuff ..they gained a tiny bit up top but overall it hurt their performance..just stay stock or bore out the stock one.
Old Dec 29, 2002 | 08:34 PM
BudaKai's Avatar
Default Re: ITR throttle body (SiRkid)
Umm, what's the difference? It loses power because it is too big? I tink it's more of a tuning issue there.
Old Jan 7, 2003 | 08:51 PM
blufke's Avatar
Default Re: ITR throttle body (tzsir)
should a dremel be used to portmatch? what tool if not that?
court76wi
Mar 30, 2009 03:26 PM
Daniel-sanB1
Jun 7, 2007 01:21 PM
Daniel-sanB1
Jun 6, 2007 10:10 PM
Nick MC
Nov 25, 2005 06:18 PM
