ITR cams....
Old Oct 30, 2005 | 10:33 AM
B18Sleeper's Avatar
Default ITR cams....
ok i was lookin into some cams and found ITR's on inlinefour.com but my question here is what is the difference between 98 Spec R and J-Spec? and would i need to get one for both intake and exhaust? this is goin into a gsr motor. thanks
Old Oct 30, 2005 | 11:10 AM
B18Sleeper's Avatar
Default Re: ITR cams.... (B18Sleeper)
can someone help me out? whats the difference and which should be used on FI motor? and do i need both intake and exhaust?
Old Oct 31, 2005 | 10:27 PM
D@nnY's Avatar
you want 01 US itrs or CTR cams whcih are the same
01 jdm itrs are the same as Us 97 type R cams
Old Oct 31, 2005 | 11:05 PM
BoOstedEM1's Avatar
Default Re: ITR cams.... (D@nnY)
Go with the Ctr like he said above.
Old Nov 1, 2005 | 02:14 PM
B18Sleeper's Avatar
Default Re: ITR cams.... (BoOstedEM1)
would gsr cams do me for 400hp? to save money?
Old Nov 1, 2005 | 03:46 PM
D@nnY's Avatar
all day
Old Nov 1, 2005 | 04:00 PM
B18Sleeper's Avatar
cool well i will just leave that a stock setup until i run into problems with it cause i dont see the reasoning behind changing it if it will work with the stock parts.
Old Nov 1, 2005 | 04:02 PM
boostfeen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">ok i was lookin into some cams and found ITR's on inlinefour.com but my question here is what is the difference between 98 Spec R and J-Spec? and would i need to get one for both intake and exhaust? this is goin into a gsr motor. thanks</TD></TR></TABLE>
....the CTR cams is what u want, but for the money that they want
for those cams on inlinefour.com you might as well just buy
a set of the buddyclub spec 5's. they are badass
Old Nov 1, 2005 | 04:03 PM
D@nnY's Avatar
Default Re: ITR cams.... (boostfeen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostfeen &raquo;</TD></TR><TR><TD CLASS="quote">
a set of the buddyclub spec 5's. they are badass </TD></TR></TABLE>
this is in the forced induction section
Old Nov 1, 2005 | 04:05 PM
B18Sleeper's Avatar
i will just stay with stock gsr cams seeing as i am using a gsr motor.
kaj
Apr 7, 2007 03:46 PM
Lsvtec_Integra
Nov 25, 2004 02:39 AM
allmotorbeasteg6
Aug 22, 2004 07:00 AM
patdemps
Jul 17, 2003 08:07 PM
vtecdc2
Sep 2, 2002 07:52 PM
