Internal WG question
Old Mar 29, 2004 | 12:02 AM
quik sol's Avatar
Default Internal WG question
Alright I have a TD05H with an internal WG which I was told is at 12 psi. Can an internal WG be adjusted down? I was wondering this because a tial is around 170 - 250 bucks...and I am trying to budget this setup. I also heard a friend of mine say something about a granger valve (or however you spell it). Not exactly sure what that is or even where to buy it.
Thanks,
Quik Sol
Old Mar 29, 2004 | 12:56 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Internal WG question (quik sol)
no , you cant adjust any wastegate below the stock setting.... only way on an external is if you get a lighter spring..... what tdo5h is it , if its the greddy it should be 5.5
Old Mar 29, 2004 | 12:59 AM
quik sol's Avatar
I will check when I get home from work
Old Mar 29, 2004 | 01:01 AM
quik sol's Avatar
Default Re: (quik sol)
I just check in the old FS post i bought it off of....it was a Mitsubishi Evo 3 turbo???
Charles B.'s Avatar
for a turbo with an internal w/g you can change out the actuator. it's the same thing as changing the sping on an external w/g
Old Mar 29, 2004 | 01:44 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (SuperDuperEG)
true i didnt think about that , the longer the actuator arm the lower the boost
tig3rxiong
Aug 4, 2004 06:40 PM
Ad4mGSR
Apr 19, 2004 08:39 PM
turbodelsolman
Mar 13, 2003 08:07 PM
uneekcrx
Jun 2, 2002 11:59 AM
