Internal vs. external wastgate?
Old Apr 17, 2003 | 06:04 PM
4drEF's Avatar
Keyboard Humorist
Default Internal vs. external wastgate?
Is there anything to be gained from switching to an external wastegate on a system that only pushes 10 psi max?
Currently I have an internal wastegated turbo. I have heard rumors that it is possible to convert to an external. How is this done properly without replacing the entire turbo with one specificly made for an external?
Old Apr 17, 2003 | 06:13 PM
Flamenco-T's Avatar
Default Re: Internal vs. external wastgate? (4drEF)
you need to replace the manifold to switch to external...
stan
Old Apr 17, 2003 | 06:53 PM
JalopySiR's Avatar
Default Re: Internal vs. external wastgate? (Flamenco-T)
Technically, if it is a T3, you could remove the internal dashpot and weld an external gate off of the flange at the appropriate location. Are you having problems? ...if it ain't broke...
Old Apr 17, 2003 | 07:55 PM
b16ahybrid's Avatar
Default Re: Internal vs. external wastgate? (JalopySiR)
The only reason to to switch to external would be if you are having boost spike/ pressure creep....of your not then just stay with the internal...
Old Apr 17, 2003 | 07:57 PM
evoeone's Avatar
Default Re: Internal vs. external wastgate? (b16ahybrid)
internal es muy malo, tiene mucho spike y creep ,
mi tial35/40mm es muy bueno no tiene spike or creep, mas smooth
Old Apr 17, 2003 | 08:00 PM
JalopySiR's Avatar
Default Re: Internal vs. external wastgate? (evoeone)
...that sounds like spanglish. Or me when I am communicating with the dishwashers...
Old Apr 17, 2003 | 08:01 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evoeone &raquo;</TD></TR><TR><TD CLASS="quote">internal es muy malo, tiene mucho spike y creep ,
mi tial35/40mm es muy bueno no tiene spike or creep, mas smooth</TD></TR></TABLE>
Yeah sure whatever he said.
Old Apr 17, 2003 | 08:14 PM
dmotoguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JalopySiR &raquo;</TD></TR><TR><TD CLASS="quote">...that sounds like spanglish. Or me when I am communicating with the dishwashers...</TD></TR></TABLE>
my damn spanish teacher hates it when i talk in spanglish i'd go ahead and leave it internal for now, but if you plan on going bigger upgrade it all at the same time....
leroyb
Mar 26, 2009 06:21 PM
ketchup!
Nov 3, 2006 11:01 AM
redlseg
Jul 20, 2005 10:31 PM
OnPointDX
Oct 25, 2003 09:03 AM
bearboy80
Oct 25, 2003 01:50 AM
