internal to external
Old Dec 15, 2004 | 04:21 AM
97cobra's Avatar
Default internal to external
is it possible to make an internaly wastegated turbo into an exteranly wastegated turbo, i have a T3 with a .60 trim and would like to do that with it because ive heard u get more power out of and external wastegated turbo, is this ture?
Old Dec 15, 2004 | 05:16 AM
oxSLEEPERxo's Avatar
Default Re: internal to external (97cobra)
you will need and block off plate, do you have a flange on your manifold for the external wastegate?
Old Dec 15, 2004 | 04:50 PM
97cobra's Avatar
Default Re: internal to external (oxSLEEPERxo)
i havent got a manifold yet im still peacing it together, ok i guess ill probly just have to buy a bigger turbo thanks man
Old Dec 15, 2004 | 04:58 PM
Islandspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97cobra &raquo;</TD></TR><TR><TD CLASS="quote">i havent got a manifold yet im still peacing it together, ok i guess ill probly just have to buy a bigger turbo thanks man </TD></TR></TABLE>
To answer your question.......... Yes you can turn an internally wastegated Turbo into an external one.
You don't need to buy a bigger turbo, just the right manifold and a block off plate as oxSLEEPERxo mention in his post.
Don't know about the power thing with an external vs. internal. I have used both and have had a harder time controlling the boost in VTEC with the external one. I haven't done a re-tune since I installed the external WG so I can't comment.
Old Dec 22, 2004 | 04:44 PM
dukduk's Avatar
Default Re: internal to external (Islandspeed)
my car creeps hella once it switches to vtec and revs go above 6K
d16y8
edelbrock kit
2.5" turboback, no cat
Old Dec 22, 2004 | 04:57 PM
Default Re: internal to external (dukduk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dukduk &raquo;</TD></TR><TR><TD CLASS="quote">my car creeps hella once it switches to vtec and revs go above 6K
d16y8
edelbrock kit
2.5" turboback, no cat</TD></TR></TABLE>
I've posted in other threads a couple of times trying to get an answer to this problem but no one responded. I think mine is caused by a combination of things like;
Manifold design (the WG port is pointing away from the direction of flow)?
Possibly the AVC-R boost controller?
WG may be to small (35mm)?
Anyways its frustrating to say the least...............
I've ordered a 46mm WG, building a new "Ram Horn" manifold and checking the AVC-R solenoid for correct operation (as well as all the wiring).
Any thoughts?
spazmatt527
Dec 5, 2011 08:05 PM
turboblack2door
Sep 8, 2009 01:47 PM
00bluecivicsi
Aug 6, 2008 09:03 AM
BOOSTEDgs-R
Feb 18, 2008 09:47 PM
jbscivichb92
Feb 3, 2005 04:02 PM
